Old 03-12-2006, 03:55 PM   #1 (permalink)
pra_2006's Avatar
Question Anyway to use Hutch or Airtel on Nokia 6265 CDMA?
hi friends i want to know is there anyway to use hutch or airtel sim card in Nokia 6265 pls reply me fast its urgent
pra_2006 is offline
Old 03-12-2006, 04:35 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Anyway to use Hutch or Airtel on Nokia 6265 CDMA?
No you can't. 6265 is a CDMA handset and Hutch and Airtel operate on GSM network. You can only use 6265 with CDMA operators like Reliance or Tata Indicom.
Old 03-12-2006, 04:59 PM   #3 (permalink)
De@d
outlaw's Avatar
nope cdma and gsm uses diff technologies and since 6265 is a cdma handset it'll only be able to work on cdma networks
more info difference between GSM-CDMA
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 03-12-2006, 05:41 PM   #4 (permalink)
pra_2006's Avatar
okay thanks for the info
pra_2006 is offline
