Old 25-11-2006, 08:41 PM   #1 (permalink)
~[::BOoYaKa::]~
Default Whats correct method to connect phone to PC?
Can anyone tell me whats the step by step corect method to connect the phone to pc through data cable??
Currently, i switch on the system, plug in the usb cable into usb port and then connect the other end to the phone. and when im finished, i just pull off the cable from the usb first then from the phone. Is it OK?
I use nokia pc suite.
Thanks.
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 25-11-2006, 09:43 PM   #2 (permalink)
JhonCena's Avatar
Default Re: Whats correct method to connect phone to PC?
lolif you know that how to connect phone to PC. they why are you asking us!!!
----------> http://www.blogofwebmasters.com/ <---------
WEBMASTERING TUTORIALS, ARTICLES AND MUCH MORE
JhonCena is offline
Old 26-11-2006, 01:18 PM   #3 (permalink)
~[::BOoYaKa::]~
No i had doubt, whether i have to disconnect it first from the pc suite interface etc. or just pull off the cable from the usb port? Will it do any harm to the phone if i just pull off the cable??
REY619 is offline
Old 26-11-2006, 05:37 PM   #4 (permalink)
JhonCena's Avatar
KENSHIN I think this icon came only when mass storage device like pen drive, memory card or mp3 player is connected. when I plug my cable nothing happen but a voice came like "TTIIINTTOOO"
JhonCena is offline
Old 26-11-2006, 05:45 PM   #5 (permalink)
dissel's Avatar
yes,when the phone connect via Data Cable using PC Suite Only phone icon on the system tray is green.
I never pull out cable from usb, I unplug the cable from the phone side...is it right?
Correct me if i am wrong.
dissel is offline
Old 26-11-2006, 06:43 PM   #6 (permalink)
Mobile Freak
reddick's Avatar
Well here is d right way to connect n dis-connect ur phone with pc :
First,to connect :
*Start-up ur Nokia PC Suite
*U'll see d programe searching for phone n an grey icon with red cross at taskbar.
*At that time just plug d cable in ur phone n within seconds u r connected
For disconnect:
*It's so simple just un-plug ur cable frm phone n it gts disconnected!
I use this procedure frm last 3 yrs. n didn't gts any problem till now
Just follow these steps n happy connecting
Hope 4 d best n Do d right :)
reddick is offline
Old 28-11-2006, 01:41 PM   #7 (permalink)
~[::BOoYaKa::]~
Yes its true, thats for mass storage devices or NGage only...
First,to connect :
For disconnect:
Thanx for that...
REY619 is offline
