20-11-2006, 05:36 PM
IM AS MAD AS HELL!!
Some Interesting facts about cell phones
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
20-11-2006, 05:42 PM
OSS Enthusiast!
Re: Some Interesting facts about cell phones
Nice Compilation....
Thanks!
Do you know, Shinigamis only eat apples???
20-11-2006, 05:44 PM
Alive Again...
but it dosent work for Sony E.........?
20-11-2006, 06:20 PM
Very good and useful collection! Thanks!
20-11-2006, 07:53 PM
De@d
thanks for sharing
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
20-11-2006, 10:49 PM
thanks dude!!
Water can flow or it can crash.Be Water my friend.
20-11-2006, 11:46 PM
OLD THINGS ,BUT FINE
I make my own Rules. I set my Own Goals. I follow the path less followed. I am What I Am
DEVIL MAY CRY
21-11-2006, 08:22 PM
-- No Easter Eggs here --
Nice info .. thanx
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
22-11-2006, 02:24 PM
Thanks
22-11-2006, 06:11 PM
!FREEWARES!
@satya
Not 4 SE phones. Only 4 Nokia's....
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
23-11-2006, 01:15 PM
Anyone know ...these kinda codes and stuff for SE phones...??
I love walking in Rain ,because no-one knows i am Crying :|
24-11-2006, 08:01 AM
Nice info...thanks
27-02-2007, 07:36 PM
IM AS MAD AS HELL!!
after buying a SE phone i tried some tricks rep me if u like(some tricks my friend told me and NET)
To view IMEI number *#06#To view Software Version enter -> * <- <- * <- * CLR (Use with Care)
To activate operator lock <- * * <- (This locks the phone to one carriers SIM card - Use with lots of care)
Press Yes to lock and No to notlock. You can also use the codes below to undo this function. USE AT OWN RISK
I have tested the function Lock to SP... At least on the 337 there's a submenu: Enter SPCK-code. There are 5 attempts, which is showed (05 attempts). At final attempt the phone beeps as a warning, 'this is the final try', when entering the menu... Wrong code exits the menu, so you are not stuck in something... When you have tried to enter the code (wrong) all five times, the menu is deactivated, and you'll get: 'Not allowed' when entering <-**<-
A "secret test mode" can be accessed on the GH337. There seems to be two methods:> * < < * > * displays software version, such as 940810 1310
> * < < * < * displays software version, such as 951024 1054
After entering this mode, the < and > keys scroll through a menu. There seems to be different menus for different versions of software.
Software version number are apparently a date and time stamp.
940810 1310 version commands:
TEXT CHECK - shows 254 messages in current language
INIT EEPROM MMI - resents NVRAM settings (User Settings).
Other, probably more recent version:
FLASH - will restart the phone, to the point of entering PIN numbers.You can't kill a 337 when pressing YES while it says "FLASH?", you must connect it to 5/12 volts first to be able to erase the flash-memory.
1-ROW TEXTS - scroll through 174 single line text messages with < and >
n-ROW-TEXTS - scroll through full-screen messages with < and >
950626 1405 version commands:
CXC (number) - The Application software's "product number". The GH337/GF337 is always "CXC 125 005"
PRG - Indication for Programming
Programming 337
Set ComPort to 9600bps, 8 data, 1 stop, no parity.
Power on phone by pressing "NO/ENDpwr".
When performing its powerup sequence the phone will send two ">>"
(ASCII 62 decimal) characters. Within 1 second, reply to it by
sending the 4 character sequence "TP1".
(I used Procomm Plus with this script "eric.asp")
[proc main ]
[start: ]
[ waitfor ">>" ]
[ pause 1 ]
[ transmit "TP1^M" ]
If everything went fine you should get the "OK" prompt back.
Test the TEST PROGRAM by sending the commands terminated by a :
PROG 0 (shows Test Program product number info)
PROG 1 (shows Test Program product date info)
PROG 3 (Shows Main Application product number info)
PROG D (Shows Main Application product date info)
Programming Calculator and Channel Indicator/RBS
To enable, send the following:
EEWR 047A 01
Wait for the OK prompt, power off* the phone and disconnect it from the interface cables. Powerup and browse through the menus.
To diasable, send the following:
EEWR 047A 00
Clearing Electronic Lock
To clear the electronic lock you have to clear the EEPROM address range 045B to 0466 by sending the commands:
EEWR 045B 00
EEWR 045C 00
EEWR 045D 00
EEWR 045E 00
EEWR 045F 00
EEWR 0460 00
EEWR 0461 00
EEWR 0462 00
EEWR 0463 00
EEWR 0464 00
EEWR 0465 00
EEWR 0466 00
Disabling the Service Provider Lock
To disable send the following command:
EEWR 1587 00
To enable send the following command:
EEWR 1587 01
Experimental Commands - Use at own Risk
To dump the application software send the following:
PREA
Bank range : 00..7F
Address : 0000..BFFF
Bytestoread : 0000..BFFF
The "additional" value returned at the end are the checksum value for the
returned program memory bytes. Note, the byte-values are always returned in
format 0000 and NOT 00.
PREA FF
Returns the application checksum, takes a few seconds.
Notes on the PH 337
1. Calculator mode is NOT available on all PH sw versions.
2. Invoking Calc/RBS mode not available for GH337 sw versions below R2A
3. SPCK attempts can be changed to 50 instead of the std 5 tries
4. The instruction LIME returns ERR but does not screw up phone
5. The instruction IMEI returns the IMEI no.
6. Pressing YES in response to FLASH? does screw up the unit.
COOL STUFF TO DO
Set ComPort to 115200bps, 8 data, 1 stop, no parity and watch all the phone commands on the screen and so on. Make a call and see what happens as well as shutting down.
Pinouts
1 In Voice
2 In +5V=External Power, 0V=Battery
3 Out Ext Speak control
4 Analog GND
5 Out Voice
6 Out +5V=POWER ON, 0V=POWER OFF
7 Out Charger control
8 Digital/DC GND
9 In 0V=normal,+5V=test, +12V=test+flash
10 In Hook
11 In TTL serial in
12 Out TTL serial out
13 In 0V for aprox 1 sec = POWER ON/OFF
14 In DC Power supply
Ericsson 318/338
The Latest Software Version is under Phone Info.
To fine tune sound and clean up any echos, place the 388 into the car kit HF 2600.
Then close all windows, engine off and type * # * # 3. The E 388 will fine-tune itself in about a few seconds.
Accessing the Service Program that is not provided with the 388.
1. Connect the 388 to Cable with RS232/TTL converter.
2. Set Comport to 9600bps, 8 data, 1 stop, no parity.
3. Power ON, wait for "2" and send "0B" to the phone. DO NOT Press ENTER.
4. R should be on screen.
5. Send TEST.BIN. (Send as a binary file)
6. 388 should answer "SP,OK".
7. R should be on screen.
DO NOT write or read from the IMEI or SPCK area! If you try that you can send the phone to service at once, because you will automatically write FE or EF to EVERY cell in the EEPROM. In other words, all the calibration values for the radio is overwritten... (NOT good)
Some commands in the ServiceProg:
eere read from eeprom
eewe write eeprom
lime xxxx xxxx xxxx xxx Learn imei no. Returns Error.
imei - Displays IMEI number
To FlashProgram a 388:
3. Power ON, wait for "2" and send "OB" to the phone. DO NOT Press ENTER.
5. send pre_xxx.bin to the MS.
6. You should recieve a ">".
7. send "0B" again.
8. R should be on screen
9. send prodload.bin to the MS.
10. recieve ">".
Done, I don't have the above files so please don't ask for them.
Interesting Informating (well I thought so
The names on the files, sj.....X45 tells you a couple of things. "sj" stands for Sofia-Jane, thats the internal name for the model and x45 stands for "sub-model". The 388 is called model 4/5. The latest 337 phones is called "cr", like in Cost Reduction. They rebuilt the oscillator from a bought-in to one built up with discrete components and that was cheaper.
Programming Channel Indicator or RBS
To enable, send the following command:
EEWR 3EE 1
To diasable, send the following command:
EEWR 3EE 0
To clear the electronic lock you have to clear the EEPROM address range 03CF to 03DA by sending the commands:
EEWR 3CF 00
EEWR 3D0 00
EEWR 3D1 00
EEWR 3D2 00
EEWR 3D3 00
EEWR 3D4 00
EEWR 3D5 00
EEWR 3D6 00
EEWR 3D7 00
EEWR 3D8 00
EEWR 3D9 00
EEWR 3DA 00
COOL STUFF TO DO
*POWER OFF
You should press the NO button a few times until Shut Down comes up on the screen, when it does press yes and this will shut down the phone properly.
Reading the Channel Info now that's it's enabled
|-------|-------|-------| D
| | | | I
| 1 | 2 | 3 | S
|-------|-------|-------| P
| | | | L
| 4 | 5 | 6 | A
|-------|-------|-------| Y
1. This is three different channels things depending on the phone state.
a. When the phone is idle, this shows "Bxxx". "B" stands for "Broadcast channel" (a logic GSM channel)b. When a phonecall is in progress, this shows "Sxxx". S stands for "Stand Alone Dedicated Control Channel" SDCCH for short.
c. When the phoncall in up, this shows "Txxx". "T" Stands for Traffic channel. The "xxx" thing is the channel number, 1-124.
2. This shows Rx Level. The values displayed is from 0 to 63. Rx Level is a indicator on how good your reception is for the moment. 0 is a signal strength of -110dBm. 63 is approx -45 to -50dBm.RXLEV is measured in dBm in such a way that incoming signal equals -110.5+RXLEV so that a RXLEV at 50 equals an incoming signal strenght at -50.5 dBm (plus or minus max deviation 0.5dBm)
3. This shows the output power in dBm.
4. This shows the timeslot used for the moment. You can see it when making a call.
5. This shows Rx Quality. Rx Quality is a measurement of how much error correction is required to the speech. 0 indicates none and as the figure rises you hear more pings and pongs on the speech as large parts of the frame are missing. If you have more RxQ then 5, you are on good way to loose your call. RxQuality reads 0-7.RXQUAL is measured by using a table wereas the biterrorrate or BER is interesting and measured in %
RXQUAL table
0 BER < 0,2 (%)
1 0,2 < BER < 0,4
2 0,4 < BER < 0,8
3 0,8 < BER < 1,6
4 1,6 < BER < 3,2
5 3,2 < BER < 6,4
6 6,4 < BER < 12,8 (here we have lost half a burst)
7 12,8 < BER
6. This shows the timing advance. The BS tells the MS to send before it should just make sure that the MS burst is comming to the BS on the right time. The TA is measured in halfbits so the distance to the BTS can be calculated as follows=1,11*TA/2. TimingAdvance reads 0-63. Co-incidentely this tells you how far you are from the base site in 550metre chunks, up to the theoretical max of 35.2km.
Pinouts
1 In Voice
4 Analog GND
5 Out Voice
8 Digital/DC GND
10 In Hook
11 In TTL serial in
Ericsson 628
To view IMEI number enter * # 0 6 #
To read all programmed texts enter -> * <- <- * <- * ->
To view phone network lock status enter < * * < (wait 3 sec)
To fast dial press phone number pos nr and # (Example: 1 5 #)
To fast dial last number press 0 #
To reset main menu language to english enter * # 0 0 0 0 #
To see battery level while phone is turned off quickly press and release on/off(NO button).
To see Extended menus (on older versions) go to MISSED CALLS, empty directory, press and HOLD right arrow button, choose menu type
To see Extended menus (on newer versions) go to READ, empty directory, press and HOLD left arrow button, choose menu type
To edit phone book Turn on extended menus and choose "EditPh.Bk".
Command set
The following commands are recongnized by the phone.Use 9600 baud, 1 stopbit, 8 data bits, no parity.
ATA Pick up phone during ring
AT+GMI Manufacturer identification
AT+GMO Request model Identification
AT+GMR Request revision Identification
AT+GMM
ATDxxx; Dial number xxx
ATH Hangup phone
AT+CFUN=? Define levels of fuctionality in the order of power consumed
AT+CFUN=0 Switches off the phone
AT+CBC Query battery level
Each command has to be followed by a 0x0A, 0x0D sequence, that is carriage return - line feed. These commands will be ackowledged with an 'OK' prompt. An
incoming call is signalled by the string 'RING' sent by the phone at 9600b in normal mode.
Portable Handsfree Unit
1 Earphone: 16 Ohm
2 Microphone: <- 2 kOhm
5 Connected to 04 (GND)
Pinouts
Left to right, keyboard up.
1 Audio Out
2 Audio In
3 Accessory Sense. GND to enable External Mic and Speaker (Analog)
4 Audio Signal GND.
5 Portable handsfree In.
6 Music Mute Out, High when phone is used.
7 In Flash Memory Voltage and Service Voltage, In 0V=normal,+5V=test, +12V=test+flash
8 Logic Out, Status On. Sources over 100mA
9 Data Out from Mobile Station. Debug messages appear here at 112KBaud when in debug mode.
10 Digital Ground and DC return
11 Data in
12 DC in for battery charging, DC out for accessory power
Ericsson 688
To reset phone language to English *#0000#
>*<<*<*> 1-row text strings. If pressing YES you can check the phones 1-row text programming in currently selected language.
>*<<*<*>> n-row text strings. If pressing YES you can check the phones n-row text programming in currently selected language.
Pinouts
1 = + external power supply. 7.2v @ 600mA.
2 = RS232 input (TTL)
3 = GND (digital)
4 = RS232 output (TTL)
5 = +5V output. Limited.
6 = Test. Switch phone off and provide +5V and switch back on. (set comms at 9600, n,8,1)
7 = Mute (0 - Normal, 1 - In Call)
8 = Internal/external (0 - External Mic/Speak, 1 - Internal Mic/Speak)
9 = GND (analog)
10 = Related to Mic/Speak
11 = BF in
12 = BF out
Ericsson 768/788To view IMEI number *#06#
To view Software Version enter * -> * <- <- * <- *
Service Provider Lock is * <- <- * but it is now called the ME lock. There are two options after selecting yes on another menu. These are lock to Network or lock to NetSubet.
Command set
AT+GMM
ATH Hangup phone
1 Earphone: 16 Ohm
Pinouts
1 Audio Out
2 Audio In
4 Audio Signal GND.
11 Data in
Ericsson 868/888
(you also get version of InfraRed driver software and text labels)
Pinouts
3 = GND (digital)
9 = GND (analog)
11 = BF in
12 = BF out
Ericsson AH 230/238 PROGRAMMINGPress and hold down FCN while entering the digits 9 8 7. You must enter the digits within ten seconds.
The text "SER NUMBER" is displayed along with the telephone's electronic serial number. The number contains 11 digits, so the most significant digit is shown for one second, followed by the other 10 digits.
ENTRY
DISPLAY TEXT
PERMISSABLE VALUE
Electronic Serial #
ESN
Not Changeable
Phone Number
MIN x
(where x is NAM choice)
10 digits
System ID
SID x
00000 to 32767
Press # to review
MIN & SID, or END/PWR
to exit the short NAM-
programming mode.
NB:
The Number Assignment Module (NAM) is programmed through the telephone keypad. There are two NAM-programming modes available; the short and the long. The short programming mode is all that is required in most cases. The long programming mode is required if a value set by the short mode is not desired.
Either mode may be used stand-alone, or the short mode can be used to set up most of the values and then the long mode can be used to make any changes desired. To enter either of the two NAM programming modes, press and hold down the FCN key while entering a specific series of digits. You must enter the digits within ten seconds.
In each programming step, you can either keep the displayed setting or value, or you can change it.
a. To go to the next step, without changing anything, press #. b. In some steps, you can "toggle" a setting from ON or OFF, or vice versa. To change the setting, press any numeric key.
In other steps, you can replace a displayed value. To replace a value, enter the digits on the numeric keys. If you enter a wrong digit, you can erase it by pressing FCN CLR.
Pressing * key restores the original value in the display.
Press # to store new setting/value and go to next step.
Press END/PWR in any step to leave the NAM-Programming mode. If you have changed anything in a step, you must store the setting by pressing # before pressing END/PWR.
Reason: Automerged Doublepost
27-02-2007, 07:43 PM
IM AS MAD AS HELL!!
after Further reading i found this (Sorry , this is not my stuff so dont rep me)
i dont have the source Coz i found this on my CD with no lable
Enjoy-
27-02-2007, 07:46 PM
IM AS MAD AS HELL!!
More Reading
27-02-2007, 07:48 PM
IM AS MAD AS HELL!!
More More reading-
27-02-2007, 07:52 PM
IM AS MAD AS HELL!!
too much reading-
28-02-2007, 02:07 AM
nice... keep it up...
28-02-2007, 05:29 PM
#19 (permalink)
IM AS MAD AS HELL!!
^^thnx ,
has n e one Some Tips and tricks for LG mobiles ?
i tried searching the net and twiddled my cell phone . but i cant find aything
28-02-2007, 06:07 PM
#20 (permalink)
Google Bot
nice info max
04-03-2007, 02:35 PM
#21 (permalink)
Nice thread man. Very handy. And you have typed a lot. Now rest your fingers
Crazy is what crazy does. So lets get crazy like hell.
