Old 18-11-2006, 10:46 PM   #1 (permalink)
tweety_bird_bunny's Avatar
Thumbs up 2 very nice NOKIA tweaks!!!!
ok guys..i dnt know whether u knw dis or not....nut i found out jst few days ago,s o here i am to share the excitement...
TWEAK 1....
dis tweak is related to setting up ur own operator logo.....i tested dis on n70 and worked fine..shud wrk with other phones too i guess.....
first u need either seleq or FExplorer instaleed..can be easily found...
nxt dwnload oplogos from mobile9.com(registration is free) or any sipmle or ur own made jpeg or bmp file wud do...transfer ur image file to ur phone...
open seleq or fexplorer...go to dat image(to the location) which u wanted to set as oplogo....
on the image..click options....goto file...click set as oplogo...the phne will restart ...let it be....
to ur surprise there wud be no change.....dnt get worried..read ON...
again open ur seleq or fexplorer.....go to c:\system\apps\phone\oplogo....
there u will might c 1 or 2 files before hand....
something like xxx__yy_z.bmp or .mbm ,,,, click on file and open it to view it and make sure it is ur file....then delete the other file or jst cut paste it to some other location jst in case u wanna replace ur previous oplogo...
there might be jst 1 file...anyways, open ur file's options and rename it to xxx__yy_z.mbm ....
restart the phone ...volla ... its DONE !!!!
in case somehow ur not able to do it or mess it out...dnt wrry ur original service provider logo will be displayed....(like airtel , cellone or hutch)...
TWEAK 2....
dis is related to the stupid RECENTLY PLAYED option in realplayer in many nokia phones.....i knw many of u mst find it realy frustrating, a loophole in privacy (
ok guys here is the way to conquer the stupid problem....make a jst small video with ur cam or select any stupid video...u may delete dat video after its done....
open seleq or fexplorer.... go to c:\system\data ... delete the file mediaplayer.dat ( the file which hosts the RECENTLY PLAYED list....the root of all problems)..
exist out of seleq or make it go in the background....check the realplayer, recently played options wud be gone....dnt get overexcited problem is not solved yet....go to ur stupid video clip location in seleq or ur gallery...play it in realplayer....u wud note dat recently played list is back again....(and the final quest begins !!!)
exit realplayer ...u may delete the clip now( preferred or jst rename ur video)....
open seleq....go to c:\system\data .... on mediaplayer.dat click on options>file...
in the properties, select READONLY to ON....
volla its DONE, 1ce again....
now whatever u might play in realplayer....the stupid clip dat u played , wud be the only file to showup in RECENTLY PLAYED list in realplayer....if u deleted or renamed it ,, it wont also play....
And so the quest was Accompalished.......
in case of any problems or queries,,, reply the thread
tweety_bird_bunny is offline
Old 18-11-2006, 11:09 PM   #2 (permalink)
De@d
outlaw's Avatar
Default Re: 2 very nice NOKIA tweaks!!!!
tweety thanks a lot for the real player tweak
u see i've got some videos [wicked smile] and i've kept them in a hidden folder so the only way to access is FEXPLORER but i was annoyed to find the "recently played" list in real player and inorder to clear the list i had to play around 5 to 6 other videos all the time
thanks buddy
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 19-11-2006, 04:58 AM   #3 (permalink)
Talking Re: 2 very nice NOKIA tweaks!!!!
a pleasure to c sum1 finding it useful.....
Old 19-11-2006, 07:44 AM   #4 (permalink)
caleb's Avatar
Interesting...will try when I find sometime for it
caleb is offline
Old 19-11-2006, 12:43 PM   #5 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Thanx for the real player tip.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 19-11-2006, 03:18 PM   #6 (permalink)
~[::BOoYaKa::]~
I was looking that realplayer tip for ages........
THANK YOU VERY VERY MUCH
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 20-11-2006, 05:48 PM   #7 (permalink)
Wink Re: 2 very nice NOKIA tweaks!!!!
u r welcome
Old 22-12-2006, 10:39 AM   #8 (permalink)
Resident Fanatic
Manshahia's Avatar
Hey good work tweety. Keep it up and give us some more too.
The real player trick is awesome.
Thnx.
__________
i m using nokia 6630 and the first tweak didnt worked for me.
anyother alternative??
Manshahia is offline
Old 22-12-2006, 03:17 PM   #9 (permalink)
Google Bot
Pathik's Avatar
tweak 1: better use oplogoman...
tweak 2: realplayer sux... try crystal player instead or pvplayer or smartmovie or divx
Pathik is offline
Old 22-12-2006, 06:11 PM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
oplogoman doesnot work on Nokia 6630
i hav tried.
any other way ??
Old 22-12-2006, 07:49 PM   #11 (permalink)
Google Bot
Pathik's Avatar
AFAIK oplogoman works on 6630...
Pathik is offline
Old 22-12-2006, 08:00 PM   #12 (permalink)
Tech Geek's Avatar
Thanks for the real player tweak
Tech Geek is offline
Old 22-12-2006, 09:06 PM   #13 (permalink)
Resident Fanatic
Manshahia's Avatar
From where to get AFAIK Oplogoman?
Old 22-12-2006, 09:18 PM   #14 (permalink)
krazyfrog
Posts: n/a
^^ Dude AFAIK is the short form for 'As Far As I Know', and its not the name of the software. Btw(By The Way) OPMAN works on my QD, so i don't see why it won't work on your 6630
Old 22-12-2006, 09:35 PM   #15 (permalink)
Resident Fanatic
Manshahia's Avatar
Opps, HE HE HE HE HE....
Anyways, i hav tried Oplogoman, when we select a Logo, it asks to restart the fone and after restart still there is no change in the Logo.
That bloody INDAirtel Shows up.
Old 22-12-2006, 09:50 PM   #16 (permalink)
try renaming the logo file to .mbm instead of .bmp and restart phne....
i apply different logos using the same technique..
follow tweak 1
Old 22-12-2006, 10:21 PM   #17 (permalink)
Resident Fanatic
Manshahia's Avatar
i changed the file format to .mbm from bmp and restarted but it didnt worked.
What can be the problem?
Old 23-12-2006, 03:05 PM   #18 (permalink)
chek in ur c:\system\apps\phone\oplogo...
there shud only be one file wid name format xxx_y_z.mbm
