Old 15-11-2006, 02:44 AM   #1 (permalink)
pra_2006's Avatar
Smile Some Secret CODES for Nokia Cell Phones
hi friends i got this from one web site i thought to share with u so here it is -
Here are some nokia mobile secret codes that i came accross.I found them to be working.
But try them at your own risk
*3370#
This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced by approx 5%.
#3370#
Deactivate Enhanced Full Rate Codec (EFR)
*#4720#
Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720#
With this Nokia code you can deactivate the Half Rate Codec
*#0000#
Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999#
Phones software version if *#0000# does not work
*#06#
For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1#
Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2#
Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3#
Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4#
SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#21#
This phone code allows you to check the number that "All Calls" are diverted to
*#2640#
Displays phone security code in use ( a very useful one - hackers rejoice ! )
*#43#
Allows you to check the "Call Waiting" status of your cell phone.
*#61#
Allows you to check the number that "On No Reply" calls are diverted to
*#62#
Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67#
Allows you to check the number that "On Busy Calls" are diverted to
*#67705646#
Phone code that removes operator logo on 3310 & 3330
*#73#
Reset phone timers and game scores
*#746025625#
Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760#
Manufactures code
*#7780#
Restore factory settings
*#92702689#
Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
**21*number#
Turn on "All Calls" diverting to the phone number entered
**61*number#
Turn on "No Reply" diverting to the phone number entered
**67*number#
Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
Menu To view Warranty menu enter *#92702689# [*#war0anty#] Phone asks 'warranty code:' Press the following warranty code: 6232 (OK) : Displays the Month and Year of Manufacture (MMYY)
7332 (OK) : Displays the date of the last repairment - if found ('DATE NOT SAVED'...) 7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY (Warning: You can only do this once - So be careful ...)
pra_2006 is offline
Old 15-11-2006, 06:47 AM   #2 (permalink)
Mobile Freak
reddick's Avatar
Default Re: Some Secret CODES for Nokia Cell Phones
It's been disscused here millions of times use search But THANKS anyways
Hope 4 d best n Do d right
reddick is offline
Old 15-11-2006, 03:20 PM   #3 (permalink)
Wandering in time...
Ankur Gupta's Avatar
a thread abt the same topic ws there a week ago....no replies nw so it has gone down the list...
seach before posting.....
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 15-11-2006, 03:24 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
This thread should be
Thread Reported...
http://www.AskVG.com/
Vishal Gupta is offline
Old 16-11-2006, 02:03 AM   #5 (permalink)
pra_2006's Avatar
oh i am sorry for that will search it next time
pra_2006 is offline
