Old 14-11-2006, 06:02 PM   #1 (permalink)
Default W700i as Bluetooth remote cotrol for PC
Hi Guys,
Has anybody used their SE W700i as a remote for their PC/Laptop and controlled Winamp etc.
I have connected my phone with PC. but still unable to use it as remote.
I also have installed SE Bluetooth software.
waht else to do?
Thanks
chits is offline
Old 14-11-2006, 07:09 PM   #2 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Default Re: W700i as Bluetooth remote cotrol for PC
This app should help you to accomplish your goal ...
http://www.bluetoothshareware.com/bl...te_control.asp
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 14-11-2006, 11:18 PM   #3 (permalink)
De@d
outlaw's Avatar
thanks for da link
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 15-11-2006, 06:46 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
download bluetooth hid files:
http://www.hidfiles.com/index.php?op...=fileinfo&id=8
infra_red_dude is offline
Old 15-11-2006, 07:06 PM   #5 (permalink)
Hi Guys ,
Thanks for the links.
I am a bit new to the stuff ,Where to put this HID file ? On phone or Laptop?
I made a HID file for W700i from SE software
I have a widcomm bluetooth dongle, I guess it has some issue (not supporting HID profile with 1.2.2.5 version of driver).
Has anybody tried with WidComm ?
Originally Posted by infra_red_dude
chits is offline
Old 15-11-2006, 11:13 PM   #6 (permalink)
Wire muncher!
dunno abt widcomm, but i use bluesoleil. it has a one click hid service. put the hid file in ur phone and activate the corresponding software on ur computer/laptop and control using ur phone.
Old 16-11-2006, 03:58 PM   #7 (permalink)
If nyone of u have succeeded in making this work / if you do succeed I guess u should write an tutorial on this ... Should be helpful I say
Old 16-11-2006, 09:56 PM   #8 (permalink)
navneeth_snr's Avatar
Thumbs up Re: W700i as Bluetooth remote cotrol for PC
Yes, It has worked for me. My phone is SE W810i. I use BlueSoleil to connect.
Just copy HID files to phone from PC. It will automatically save to Remote Control Folder.
Open BlueSoleil application, Search and connect your phone. Once it gets connected, Enable Bluetooth Human Interface Device Service in the BlueSoleil application. Your phone will automatically ask to use Remote Control and select yes.
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
navneeth_snr is offline
Old 17-11-2006, 12:11 PM   #9 (permalink)
Hi ,
I used the SE Software to create the HID File for W700i , but when I copied the file on phone it doesn't recognize it, do I have to copy in some special folder, I have copied in 'other' folder.
Anyway I will try with Bluesoli app...
also Is their any issues with Widcomm device or its driver etc ?
chits is offline
Old 17-11-2006, 12:46 PM   #10 (permalink)
Originally Posted by chits
Hi ,
Use My Phone Explorer, and just drag to the HID files to root (just like copying a java application). It will automatically save to remote control application.
Navaneeth
Old 03-12-2006, 05:21 PM   #11 (permalink)
has anybody used W700i as TV remote?
chits is offline
Old 03-12-2006, 09:12 PM   #12 (permalink)
De@d
outlaw's Avatar
the ir range would be pretty low ; and u'll have to be very near to da t.v so the application beats the purpose of being a remote
shoot them.
outlaw is offline
Old 03-12-2006, 11:00 PM   #13 (permalink)
Wire muncher!
none of the java phones can be used at TV remotes!
Old 03-12-2006, 11:15 PM   #14 (permalink)
De@d
outlaw's Avatar
i wonder why da t.v remotes are still IR and not bluetooth
shoot them.
outlaw is offline
Old 05-12-2006, 04:28 PM   #15 (permalink)
I think it all depends what the Tv has ..most of the TV/DVD player has IR (though some has RF , in which point of scale is not required) .
TV are not having Bluetooth coz its a costly technology as compared to IR, also then the remote needs to be bluetooth enabled...
Now I am able to use my phone as remote control my laptop, it is very helpful While I watch movies with lappy working as DVD player (Audio/Video connected to TV via S-Video)...
__________
Has anybody used Bluetooth Pen ??
chits is offline
