Old 12-11-2006, 01:34 PM   #1 (permalink)
Question how to create 24 chord polyphonic ringtones?
NagpurDaMunda is offline
Old 13-11-2006, 01:28 PM   #2 (permalink)
tuxfan's Avatar
Default Re: how to create 24 chord polyphonic ringtones?
You will need a MIDI composer. In a MIDI composer, you can select from the available instruments (usually about 128 of them). Each instrument is a channel. You can play one at a time and keep recording. In the end play all of them together for a piece of music.
Do you know layers in photoshop? Each channel in a MIDI file is like a layer in photohsop files
tuxfan is offline
Old 13-11-2006, 04:59 PM   #3 (permalink)
is number of channels same as no of chords?
Old 13-11-2006, 06:09 PM   #4 (permalink)
tuxfan's Avatar
Do you know what are chords?? Chords are 3-4 notes played together. Of course, they are not any random notes, but specific ones and those that create proper sounds for example C-sharp chord, etc.
In some case, channels can behave like chords. For example, if there are 4 channels of the same instrument playing at the same time, it will sound like a chord. If channels are different instruments, it won't sound like sound like a chord.
Hope your basics are clear
tuxfan is offline
Old 14-11-2006, 12:36 PM   #5 (permalink)
can u please name any of the midi composers ?
Old 14-11-2006, 01:11 PM   #6 (permalink)
tuxfan's Avatar
Presently I don't know about any! I had one old one which was made for Win3.1. But I will have to search for the CD in the pile
Try googling.
tuxfan is offline
Old 19-11-2006, 12:40 PM   #7 (permalink)
try cakewalk or fruityloop
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
