Re: How to uninstall an application...??
Go to Application Manager in your cell and delete the app that you want from the list of installed apps. Or you can go through FExplorer or FileMan, and delete the app from E:\System\Apps folder.
When i go to tools>app manager there aint any applications shown... it says **No files**, so i have to use the other method. But tell me why did the app manager aint showing any applications?? Is it normal?
Thanx.
[::Eddie n Benoit Live Forever::]
