Old 05-11-2006, 01:22 PM   #1 (permalink)
Exclamation help!! comwarrior inside!
i have a nokia n70..a file named comwarrior got into it via bluetooth.the phones switched off and on automatically.after a minute or two it again went off.the cycle repeated.the operator logo on screen was replaced by a logo "ComWarrior-Matrix has you".i removed the 512 MB MMC and switched on and restored the phone to original settings.there was no problem.but when i put in the MMC it happens again.i formatted the MMC and put it back.still the same problem!!.i used a card reader but nothing was found.when i use another MMC there is no problem.
does this mean i have to change the first MMC? plzz help
shidhin4ever is offline
Old 05-11-2006, 02:03 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: help!! comwarrior inside!
There are two method to solve this problem-
A: Remove the mmc from your cell. Format your phone memory. Using a card reader format your memory card through a pc separately. The thing is the virus spreads from phone memory to memory card. Thats why you have to format them separately.
B: Download AntiCommWarrior and install it to your memory card. It'll automaticaly scan and delete the virus.
