Old 28-10-2006, 07:09 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Question 6600 query
for some reason i am unable to send files frm my fone to my pc thru bluetooth however wen i send files frm my pc to my fone it successful.... frm fone to pc it says unable to connect but also i control freak is working absolutely flawless
i tried to send a file to SE t630 and was successful ... only sending to my pc says 'unable to connect'
http://beingmanan.com
iMav is offline
Old 28-10-2006, 10:12 PM   #2 (permalink)
gaurav21r's Avatar
Default Re: 6600 query
Try sending the files from Mob to Comp thru Data cable to see if anything is wrong with the software.
I think its a problem of the 'passcode' service in Nokia phones
Does the PC turn up in the Devices list?
gaurav21r is offline
Old 28-10-2006, 10:38 PM   #3 (permalink)
kirtan's Avatar
Assuming that u use win xp mav3,first of check whether windows is not blocking ant incoming services.Some services can be blocked by windows firewall or by any other firewall that u might have installed on your pc.u can check for that in the control panel->windows firewall.clear any blocked services belonging to bluetooth file transfer in the firewall settings.
Or else u can use fsquirt for bluetooth file tansfer.fsquirt is a inbuilt windows app for Bluetooth file transfer.u can start this by typing fsquirt in the run window.
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 28-10-2006, 11:25 PM   #4 (permalink)
iMav's Avatar
guys first of all i hv been using this without a hitch for the past 6-7 months all of a sudden this thing has cropped up .... i can pair my fone with the pc .... but wen i try to send something to the pc it says max conx (if paired) or unable to connect
__________
how do i set the ports .... my pc currently shows com 5 in local services for bluetooth serial port and com4 in client services for bluetooth serial port
iMav is offline
Old 29-10-2006, 09:24 AM   #5 (permalink)
D PrankMaster
prankie's Avatar
maybe this cud help u..
rightclick on the bluetooth icon on the taskbar and select recieve file, then send the files frm ur phone to ur pc..
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 30-10-2006, 08:06 PM   #6 (permalink)
iMav's Avatar
ftp device not found on this device ....
iMav is offline
