Old 28-10-2006, 04:19 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default how to increase sound of k750i
I have k750i but sound of my mobile isn't like w550i or w800i can anyone telll me how can i increase volume of k750i
MasalaStation.com
myhotdog is offline
Old 28-10-2006, 06:14 PM   #2 (permalink)
Default Re: how to increase sound of k750i
im also using k750i ..and when i compare its sound with w550i ..
then my phone rocks..slight diff..but not easy to catch
also, it depends on the music format ur using...!!
neerajvohra is offline
Old 28-10-2006, 06:47 PM   #3 (permalink)
Kiran.dks's Avatar
K750i sound is really good. There is no need to do such things. There is a problem in playing amr files where sound crackes, but MP3 playback is awesome. Play MP3 files from Media player with equalizer settings rather than opening files from File manager. It should sound good.
Kiran Kumar R
Kiran.dks is offline
Old 05-11-2006, 04:51 PM   #4 (permalink)
I think kiran you r not getting me ..I'm saying volume of my phone sucks big time then other phone (i.e. w550i)
MasalaStation.com
myhotdog is offline
Old 17-11-2006, 10:21 PM   #5 (permalink)
crap crap crap ..I again updated my firmware from SEUS and after upgrading to latest firmware sound level gone 2 more blocks down and quality like 50 Rs radio
MasalaStation.com
myhotdog is offline
Old 18-11-2006, 05:24 PM   #6 (permalink)
Don't compare with W550i, as if I remeber W550i have 2 OR 3 speakers.
Stick is offline
Old 18-11-2006, 06:02 PM   #7 (permalink)
Wandering in the zone ...
manas's Avatar
Wink Re: how to increase sound of k750i
If you just want to increase the volume of K750i then here is a small trick.When you play songs then go to the ringtone settings and set the song which you want to hear as the ringtone.Also set the ringtone volume to the max.You should get high volume.
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 19-11-2006, 12:27 PM   #8 (permalink)
dinesh_mettur's Avatar
hi am also having having 750i , u turn off the increasing ring in sound and keep the ringing vol to 8 our phone rocks a great pa...
if u hav still problem just wait for few days sony ericsson is going to release a new firmware in mid dec update it, it will fix u r problem......
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 19-11-2006, 11:10 PM   #9 (permalink)
how do u know tht sony gonna release a new firmware in mid dec??? any source??
Old 13-12-2006, 02:32 PM   #10 (permalink)
Kalyan's Avatar
Hi..
i may be late to answer.. but this would help u. i bought the same fone and found the answer to that in some other forum. when u play the song from the media player, go to more> equalizer> keep the preset selected other than mega bass and the option (manual) appears on right soft key. press it and u will be given the equalizer bars. increase all the bars to the max and u will observe a 30 or 50% increase in sound.
P.S. :: beware. the sound would be very loud if u use ear phones with this setting. only use the loud speaker for this setting. Revert to the preset if u use earphones.The megabass preset rocks with earphones and is a real bliss to hear..
Kalyan is offline
Old 17-12-2006, 01:31 AM   #11 (permalink)
sourav237's Avatar
recent firmware upgrade reduces the volume of k750i. It's Se's trick to sale w serie phones
sourav237 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/39767-how-increase-sound-k750i.html
Thread how to increase sound in w810i | www.lasyk.net : Mobile Phone Forum | BoardReader This thread Refback 10-07-2010 08:06 AM
