Old 25-10-2006, 10:39 PM   #1 (permalink)
Default how do connect to net with cell?
how does one connect to the net using a mobile phone.
should one connect it to a pc or is it possible directly?
and which is the best service provider in this regard.
thanks
viruses is offline
Old 26-10-2006, 01:01 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: how do connect to net with cell?
u can connect the fone to ur pc and surf the net thru ur pc using ur fone as a modem and the conx is provided by ur service provider (fone ka)
u can also browse the net using ur fone (any gprs enabled fone allows u to do so)
airtel and hutch both are good
http://beingmanan.com
iMav is offline
Old 26-10-2006, 01:28 AM   #3 (permalink)
Tech.Masti's Avatar
but Hutch has no Unlimited plan (i think), Airtel has unlimited plan... charges depends on area basis
Tech.Masti is offline
Old 26-10-2006, 12:35 PM   #4 (permalink)
thanks
You Need GPRS Cable (data cable is diffrent) suitable to your Phone model, prefer to buy from same company who mfg. your mobile phone.
Stick is offline
Old 26-10-2006, 02:27 PM   #5 (permalink)
i got a nokia 3230
viruses is offline
Old 26-10-2006, 03:47 PM   #6 (permalink)
first of all activate gprs with your service provider, install setting sent by service provider, connect using bluetooth or irda or data cable.
sanju is offline
Old 26-10-2006, 11:42 PM   #7 (permalink)
thanks sariq.gprs is free for me only downloads are charged.
viruses is offline
