Old 19-10-2006, 07:25 PM   #1 (permalink)
Default Please help me play more than 50 songs in itunes in motorar v3i
i have a motorazr v3i.with 1 gb memory card.the itunes in the phone does not play or transfer more than 50 songs saying 50 is its max. capacity but i still have 700 mb free.i want to transfer and play more songs.please help me.
if not itunes,than is there any other software that shall help me do this?
thnx.
ranjodh
RJ THE GREAT
ranjodh is offline
Old 19-10-2006, 07:51 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Please help me play more than 50 songs in itunes in motorar v3i
if u hav a bt dongle send em using that...
Pathik is offline
Old 19-10-2006, 08:06 PM   #3 (permalink)
the bluetooth transferrred songs dont run in motorola phones,fyi.they just dont open
RJ THE GREAT
ranjodh is offline
Old 19-10-2006, 11:07 PM   #4 (permalink)
krazyfrog
Posts: n/a
If i remember correctly, V3i has two players, one is the iTunes which has only 50 track capacity and a regular music player (as found on other motorola phones) which can play any number of songs. If i'm not wrong, you can try playing through that other player. It can probably be accessed through the file manager in the phone, by opening a song in the file manager.
Old 19-10-2006, 11:16 PM   #5 (permalink)
kirtan's Avatar
hey dude i think the moto razr v3i is expandable to only 512mb.in any case just follow these steps to transfer the songs.
Using A Cable:
conncet ur razr to ur pc.wait a while for the mobile device to be able to recognised as a mass storage device.Once this is done double click on the my computer and u can see a drive like thing apart from the regular things.it will be named on the memory cards name.click this.U can see two folders.itunes and mobile.click on mobile and then goto audio.dump in all the songs which u want to this folder and u r done.to play these songs go to extras in phone menu and then multimedia->sounds.u can see all the songs listed if the storage device selected is the memory card.
Note:these songs do not paly in itunes.
using a card reader:
plug in ur micro sd card into the microsd card adapter that came in bundled with ur phone.Once ur done plug this into the card reader and just follow the above procedure by going to mobile->audio in the drive contents.
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 20-10-2006, 01:55 AM   #6 (permalink)
dIgItaL_BrAt's Avatar
here's the soution
http://motomodders.net/Default.aspx?...709&view=topic
dIgItaL_BrAt is offline
Old 20-10-2006, 09:01 AM   #7 (permalink)
Unhappy Re: Please help me play more than 50 songs in itunes in motorar v3i
the other player does not play in background.and digital brat,btw,that link is not for v3i.i thought my work was done but...anyways,pls try guys,i shalll always b thankful t u for this.
RJ THE GREAT
ranjodh is offline
Old 02-11-2006, 04:55 PM   #8 (permalink)
pls help me guys....pls
RJ THE GREAT
ranjodh is offline
Old 02-11-2006, 06:29 PM   #9 (permalink)
prasad_den's Avatar
dude..check the forums in the following sites.. You'll get a solution..
www.motomodders.net
www.howardforums.com
prasad_den is offline
