Old 19-10-2006, 03:02 PM   #1 (permalink)
SE><IE
Posts: n/a
Default FM on RAZR
Just bought RAZR v3i . Its really cool except that it lacks an FM. Is there any application which will allow tuning to FM channels?
and yeah! what about installing applications on RAZR. How do I install them?
Old 19-10-2006, 04:29 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: FM on RAZR
Installation of FM also needs some hardware. So you cannot simply tune to FM by only application.
Kiran Kumar R
Kiran.dks is offline
Old 19-10-2006, 05:24 PM   #3 (permalink)
SE><IE
Posts: n/a
Thanks can you shed more light on this? Or maybe direct me to a site
Old 19-10-2006, 07:16 PM   #4 (permalink)
Google Bot
Pathik's Avatar
razr has only java apps.. So forget it.. Also u can get a fm headset..
Pathik is offline
Old 19-10-2006, 07:54 PM   #5 (permalink)
SE><IE
Posts: n/a
thanks. Can anyone guide me on how to install java apps in RAZR v3i. The manual doesn't tell anything.
Old 20-10-2006, 09:11 AM   #6 (permalink)
Kiran.dks's Avatar
Copy the games/applications to the phone memory. Then just install. During installation it will ask for location of install viz. Memory stick or Phone memory.
Kiran Kumar R
