Old 15-10-2006, 06:57 PM   #1 (permalink)
Stalker's Avatar
Question Mobile with GPRS
Hey guys, can u suggest me a gud cell with GPRS capability & preferrably gud music speaker,data cable support, no need 4 a camera. My budget is very low...abt 4k-5k.
Reply soon.....Thx in advance...
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 15-10-2006, 07:02 PM   #2 (permalink)
prasad_den's Avatar
Default Re: Mobile with GPRS
You can get a NOkia 6020 for abt 5K.. has all the above mentioned with camera - a very basic one with video recording.. But not sure if any phone n this range will support mp3..!!
There's also a Motorola phone with all the features you have mentioned - don't know the model.. search it in this forum
You can also look at sony ericcson J series - j220 or j300
prasad_den is offline
Old 15-10-2006, 08:47 PM   #3 (permalink)
krazyfrog
Posts: n/a
If you are ok with second hand, then try for a used N6230. You can find one in good condition within your budget and it has more features than you'll ever need. I find it a better deal than a new phone with less features.
Old 15-10-2006, 09:29 PM   #4 (permalink)
lalu's Avatar
Post Re: Mobile with GPRS
go for nokia 3220 it has edge enabled and videocamera and it cost below 5k
lalu is offline
Old 15-10-2006, 09:42 PM   #5 (permalink)
Google Bot
Pathik's Avatar
2nd hand ngage qd... Take Only s60s
Pathik is offline
Old 22-10-2006, 01:32 PM   #6 (permalink)
dinesh_mettur's Avatar
no the cost u specified is not possible for u r desire
go for se k 510i it cost around Rs 6.5 k
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 22-10-2006, 02:02 PM   #7 (permalink)
Stalker's Avatar
does the k510i hv expendable memory, gud music speaker??is a data cable bundled with it??
Stalker is offline
