Old 12-10-2006, 11:21 PM   #1 (permalink)
Default HELP...unable to unclock my nokia fone
i've got a nokia 6030...i had enabled automatic key guard and the security code on it..now a few moments ago i was fiddling with the fone and entered the wrong code 3-4 times..after dat when i entered the correct code ,it didnt accept it..kept flashing "code error"..i knoe that entering the wrong pin code 3 times locks the fone,but does this also happen with tthe security code?
now wat am i supossed to do?pls help...
Somedays you\'re the dog,
somedays you\'re the hydrant.
kreigsmarine is offline
Old 13-10-2006, 12:06 AM   #2 (permalink)
clmlbx's Avatar
Default Re: HELP...unable to unclock my nokia fone
yes it also happens with the security code . if you entered the wrong code few times then it will lock for some 15 to 20 minutes . it can not be unlocked by the corect code. unlock the phone by entering the correct code after 15 to 20 minutes
clmlbx is online now
