Old 12-10-2006, 10:33 PM   #1 (permalink)
Default is there any mobile application which shows the mobile screen on my computer monitor
hi everybody
i want to know how do mobile review people capture the screen shots of mobile.
Is there any mobile application for sony ericsson k750i, which shows the mobile screen on my computer monitor.
harikrishnat is offline
Old 12-10-2006, 10:54 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: is there any mobile application which shows the mobile screen on my computer monitor
For smartphones there are lot of applications which can take screenshots. These are saved as images in the phone's memory and can then be transferred to a pc. For regular phones (like k750i) you can't take screenshots. The screen shots you see on mobile reviews are actually photographs taken of the phone's screen with a camera.
Old 12-10-2006, 11:46 PM   #3 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Well my Ngage comes with a sw called Screen shot for the said purpose.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 13-10-2006, 05:43 PM   #4 (permalink)
prasad_den's Avatar
Moto E398 has a PC software called msnap... Connect moto to your PC using the cable, run msnap and capture images.. Images are directly stored on the PC.. Simple..!! Some samples..
prasad_den is offline
Old 13-10-2006, 10:41 PM   #5 (permalink)
Google Bot
Pathik's Avatar
d u need live coverage or snaps
Pathik is offline
