Old 08-10-2006, 06:29 PM   #1 (permalink)
::vicky::'s Avatar
Unhappy All K750i Users Plz Help!!
hi guys
i have questions regarding k750i
1) is there any way to improve the sound quality of k750i speaker
2) from where can i download the firmware of k750i and is it legal and safe
3) how can i update my firmware
plz help thanks a lot
::vicky::
::vicky:: is offline
Old 08-10-2006, 10:41 PM   #2 (permalink)
Default Re: All K750i Users Plz Help!!
You must be having a CD provided with your phone.
time to use that, find and install SE upgrader service, It has a Flash tutorial on how to update firmware.
ProDemon is offline
Old 09-10-2006, 12:36 AM   #3 (permalink)
dOm1naTOr's Avatar
Get the external speaker set from SE itself- the one which is given away with SE W810i. Its really gud nd the phone can be charged while playing.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-10-2006, 04:49 AM   #4 (permalink)
if u want u can update ur firmware from K750i to W800i
Upgrading to a W800i: Pros and Cons
Pros
* Louder music volume; built-in speaker and headphones
* The WALKMAN media player; better organised music
* Call quality seems to be slightly better
* Low-light camera shots better (with camera mod)
* Handset worth more; higher resell value
* Free upgrade
* Several other technical updates
Cons
* You lose the activity menu, as this button is now used for the WALKMAN screen
* Phone slightly slower (probably just my phone, its was going slow before)
For more visit my blog and see this archived post !!
complete method being written for K750i owners
Neeraj Blog
Hope this will help you..
neerajvohra is offline
Old 10-10-2006, 06:34 PM   #5 (permalink)
::vicky::'s Avatar
can the firmware be installed by bluetooth
Old 11-10-2006, 11:28 AM   #6 (permalink)
aadipa's Avatar
NO. Firmware in phone is like OS in PC. Firmware is installed when phone is switched off, so there is no chance of bluetooth working. You can use only data cable for that.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 11-10-2006, 07:34 PM   #7 (permalink)
::vicky::'s Avatar
can anyone explain me the procedure
Old 12-10-2006, 12:41 AM   #8 (permalink)
u can check out the link mentioned above in my post...
all the details with images and stuff tht u need are being provided..
Old 12-10-2006, 02:42 PM   #9 (permalink)
montsa007's Avatar
k750i can be flashed to become w800i the quality i donno and firmware is available at the local mobilewalla shop
montsa007 is offline
Old 13-10-2006, 12:10 AM   #10 (permalink)
::vicky::'s Avatar
ok guys one more thing can i switch back to my k750i if i update to w800i
Old 13-10-2006, 04:31 AM   #11 (permalink)
I think only available FLASHER ( 750 to 800 ) is not free, thay take $5 for each phone.
CAUTION : After flashing you will loose any guarantee your phone have.
ProDemon is offline
Old 13-10-2006, 01:15 PM   #12 (permalink)
aadipa's Avatar
I have seen a post, which shows how to install W800i firmware on K750i from SE official website.
While upgrading firmware, you need to run given exe file first. Then the phone is detected as W800i and its firmware is installed. Since both W800i and K750i are same phones with different outer case, this won't make any difference to phone functionality, it becomes a complete W800i, without any quality loss.
If you want to revert back to K750 firmware, just don't run the exe and phone is detected as K750, and its firmware is installed.
I have not tested this, try at your own risk.
K750i to W800i Via SEUS and DCU60
aadipa is offline
Old 13-10-2006, 04:38 PM   #13 (permalink)
hey bro r u sure that external speakers of w810 r compatible with k750 and what is its price THANKS
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 13-10-2006, 06:13 PM   #14 (permalink)
aadipa's Avatar
ALL accessories made for K750i are compatible with W800i as both are same phones at hardware level, only external case is different. At software level, firmware is interchangable.
aadipa is offline
Old 13-10-2006, 08:53 PM   #15 (permalink)
Firstly try out at your own risk....and yes this method will
work with RED phones only up to CID36...
One of my friend tried this method and this worked..
also for CID49 phones..there is still no way to update the firmware
The warranty will go.
You can flash back to k750 ,with the original updater service..
hadnt tried though..but seen somewhere in other forums..it works
Old 14-10-2006, 09:52 PM   #16 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
my best advice.......PLEASE UPDATE UR FIRMWARE...
UR PROBLEMS WILL BE SOLVED
download first seus software.....for more info go to esato.com
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 14-10-2006, 10:10 PM   #17 (permalink)
gxsaurav
Posts: n/a
SEUS has a new version of K750i firmware,
R1DB001
- Released on SEUS for the K750 on 14/09/06.
- Software versions:
LCD 0
Camera 5.3
However this has given problems with the sound quality, & the only way to correct that is to use FAR manager & replace old firmware files
I would say, if u R1CA021 firmware, then don't upgrade
