Old 06-10-2006, 10:27 PM   #1 (permalink)
kool's Avatar
Default wav and mp3 tone is not showing in nokia 3230 *
Hey guyz......
I've Nokia 3230 (v.3.0505.2 ) with 512mb (187 used) memory card! Problem is that under Profile>> ringtones>> its not showing any .mp3 and .wav tones.
i've few tones in .wav and songs in .mp3 format. before ten days it was showing and was also able to play as ringtones. I've faced this problem till now 5times. And after formatting it starts working normally. I mean mp3 and wav as tone.
Whats the problem with my handset? is there any file missing/changed/corrupted in my system folder of my phone?? I've FExplorer.
__________
help me someone.......
kool is offline
Old 06-10-2006, 10:34 PM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: wav and mp3 tone is not showing in nokia 3230 *
Generally all Nokia Mobile Phones suffer from this deficiency
Every phone except the N Series work extraordinarily well with either 128 MB or 256 MB Cards.The moment you switch over to either 512 MB or 1 GB,the time taken to switch from phone memory to card memory is extremely long (sometimes it takes even 3 minutes)
Also check your phone for any viruses and always install a good antivirus and avoid enabling Bluetooth in Public Places
Let me know
techtronic is offline
Old 07-10-2006, 01:43 AM   #3 (permalink)
18 Till I Die............
Default Re: wav and mp3 tone is not showing in nokia 3230 *
I have been using a 512MB card since long on my 3230 without a problem.
@Kool check if there is a folder named 'Sound clips' in your MMC card. 3230 looks for ringtones in that folder.
http://www.bash.org/?258908
mehulved is offline
Old 07-10-2006, 02:40 AM   #4 (permalink)
hey just remove the mmc & format the phone by pressing 3, call button & # while switching on ur phone,,,,,,
DO REMEMBER THAT U HAVE ENOUGH BATTERY OTHERWISE IT MAY DAMAGE SYMBIAN....& IT WILL BE A LONG TROUBLE DEN.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 07-10-2006, 09:32 AM   #5 (permalink)
krazyfrog
Posts: n/a
Make a folder in E:\Sounds\Digital (type exactly as above) in your memory card and move all the mp3/wav/amr/mid files that you want to use as ringtones in this folder. Nokia smartphones can recognise ringtones only if they are placed in this folder. If kept in any other folder they won't show up in profiles although they can be played in mp3 player.
Old 07-10-2006, 09:38 AM   #6 (permalink)
Google Bot
Pathik's Avatar
did u install any ogg,wmv codec or any player
Pathik is offline
Old 07-10-2006, 10:25 AM   #7 (permalink)
mAYHEM's Avatar
Anything in E:\Sounds\* can be set as ringtone.
http://www.speedtest.net/result/445135884.png
http://valid.canardpc.com/show_oc.php?id=821188
mAYHEM is offline
Old 07-10-2006, 12:08 PM   #8 (permalink)
kool's Avatar
yes i've installed, wma plus player, dvd player, smart movie player.
kool is offline
Old 07-10-2006, 12:19 PM   #9 (permalink)
Google Bot
Pathik's Avatar
try removing the wma recog file 4m e/system/recogs
Pathik is offline
Old 07-10-2006, 10:56 PM   #10 (permalink)
kool's Avatar
Thnx..... thank u very much...... my problem solved........
You DIGIT guy are realy best!!
kool is offline
Old 08-10-2006, 09:04 AM   #11 (permalink)
krazyfrog
Posts: n/a
Thumbs up Re: wav and mp3 tone is not showing in nokia 3230 *
Thanx. Always happy to help.
