Old 27-09-2006, 07:40 PM   #1 (permalink)
Default Bluesoleil prob...plz help
hi all,,
i hav just bought new bluetooth dongle of BlueSoleil, now the problem is it isnt workin in XP SP2, OS is not able to detect it, i hav installed the drivers too but whenver i click on the bluesoleil's icon, " DONt SEND " window open n by clickin on dat window it close the application, so am not able to do any operation.
so i have installed WIN98,now its workin fine but again one prob has occured am not able to connect to web using dial up connection, i hav installed pc suite and modem drivers too, whenver i click on dial up icon, nothing happens just verifying username and password window appear but nothing happpens.. and also it doesnt display the error ... am using N-gage QD,, whn i chekded using nokia 6600 it was workin fine, n had connect to the web too,,, but y not in N-gage QD ?????? plz help
I'm very responsible, when ever something goes wrong they always say i'm responsible.
VirusKiller is offline
Old 27-09-2006, 08:40 PM   #2 (permalink)
18 Till I Die............
Default Re: Bluesoleil prob...plz help
Try downloading new drivers from bluesoliel site and see if they help.
http://www.bash.org/?258908
mehulved is offline
Old 28-09-2006, 02:51 AM   #3 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Even i have a bluesoleil one ... it says device not supported working in evaluation mode 5mb data tranfer only ... bluesoleil sw starts anytime i run any bluetooth service from nokia pc suite or oxygeb manager and i am stuck with that 5mb limit (have to quit and restart bluesoliel sw for bluetooth to work again) ... is there any workaround for this ??
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 28-09-2006, 10:14 AM   #4 (permalink)
The thing is that you'll are downloading the wrong driver. I have posted this before on which driver to download, just search for it. If you'll download the wrong driver then it will give you only limited transfers.
__________
You'll should be downloading standard version. Read their site, there should be info on what to download exactly.
mehulved is offline
Old 28-09-2006, 12:37 PM   #5 (permalink)
^^ I didn't downloaded any driver .. just installed the setup from the cd provided with the device.
Old 28-09-2006, 12:52 PM   #6 (permalink)
Then the dongle is not registered as supported by Bluesoliel. Check their website if you can get more info.
mehulved is offline
Old 28-09-2006, 01:54 PM   #7 (permalink)
nik_for_you's Avatar
i am having bluesoliel and its working fine with sp2. ther must be some problem with driver ..
I AM REBEL
nik_for_you is offline
Old 28-09-2006, 02:45 PM   #8 (permalink)
Not much help from their site .. i even send them an email regarding this and all i got from their site till date is spam.
Even if i manage to stop bluesoliel sw to run every time i run pc suite my work would be done so any suggestions ?
Old 30-09-2006, 10:35 PM   #9 (permalink)
shoegoe's Avatar
ive also faced such problms..
ive got a class1 bt working with Bluesoleil(driver released around 2004).. it worked well(auto registered)...But when i updated the driver to 2006 version, it said that not regeisted and 5mb limit... When i rollled back to the 2004 version, all went ok...
just try the diff versions of the drivers ...i thnk one will def work..
shoegoe is offline
Old 01-10-2006, 09:32 AM   #10 (permalink)
mAYHEM's Avatar
Try to use Widcomm Drivers they should also work fine.
http://www.speedtest.net/result/445135884.png
http://valid.canardpc.com/show_oc.php?id=821188
mAYHEM is offline
Old 01-10-2006, 11:41 AM   #11 (permalink)
AJJU
azzu's Avatar
Smile Re: Bluesoleil prob...plz help
i too got similar problems with bluesoleil bluetooth dongle and later i solved it iam usin n6600 and iam connectin the net fine
OK this how u do it
(for viruskiller) firstly uninstall all nokia drivers and bluesoliel software and then if u want to trasfer huge data above 5mb u should install NOKIA PC SUITE and and transfer ur data if u want to use d net (dailup) install bluesoliel software and click on the dailup icon it connects fine....ohh and u have to configure string ur connection is airtel its AT+CGDCONT=,,"airtelgprs.com".I FORGET IF BOTH OF THE SOFTSS ARE INSTALLED(bluesoliel and pc suite)pc suite wont work
WILL work fine
IF IAM HELPFULL PLZ ADD REPUTATION
azzu is offline
Old 05-10-2006, 01:12 AM   #12 (permalink)
virus_killer's Avatar
thnks azzu,,,,
__________
but the problem is Win XP doesnt detect the bluetooth dongle ??? hav reinstalled the drivers too. but still.......
Last edited by virus_killer; 05-10-2006 at 01:12 AM. Reason: Automerged Doublepost
virus_killer is offline
Old 05-10-2006, 02:07 AM   #13 (permalink)
My prob has been solved by using an old version
Old 05-10-2006, 02:30 AM   #14 (permalink)
but how ??
Old 05-10-2006, 06:20 PM   #15 (permalink)
I just installed an older version of bluesoleil sw and now there is no 5mb limit. It sometimes doesn't finds my phone (n gage classic) but that is solved by searching for bluetooth devices (looking for new paired device option) from the phone and it works fine.
Old 09-10-2006, 04:51 PM   #16 (permalink)
spice it up
kapsicum's Avatar
hey ppl is there any alternative to bluesoleil???
or can any1 gimme running older version setup file of it (upload it on rapidshare,megauploads,etc)
kapsicum is offline
