22-09-2006, 01:57 PM
Airtel GRPS
Hi friends!
Lets discuss about Airtel GRPS related issues.
Kiran Kumar R
22-09-2006, 02:24 PM
Re: Boosting Airtel GRPS speed
3 to 7kbps is too low. are you talking about 3 to 7KBps?
1KBps=8kbps
22-09-2006, 07:00 PM
Beneath The Eyelids
3 to 7Kbps is perfectly ok i would say.
22-09-2006, 07:15 PM
download manager mention speed in KB/s , so in your case 3-7 KB/s means 24-56kbps which is good speed for gprs connection, and your handset k750i is not EDGE enabled, you cant get higher speeds without changing handset to EDGE enabled handset.
so this is the maximum speed in your case.
26-09-2006, 11:33 AM
I appreciate your feedback. Thank you!
Kiran Kumar R
27-09-2006, 09:41 PM
I also use Airtel GPRS. For my region it is 199 Rs per month (unlimited download) !! Believe it, it was Rs 99 only (unlimited download) 2/3 months back.
I get average speed of 7/8 KBps, and on lucky times limewire/free download manager show 10 KBps. Btw using it on a NOKIA 6070 for past 1 month.
27-09-2006, 11:34 PM
Guys, I'm getting only 4 to 5KBps speed in N70. So I would say it is the normal speed.
28-09-2006, 10:44 AM
Alan..if ur mobile is Egde enabled, u can get speed upto 12KBps...contact Customer care.
Kiran Kumar R
02-10-2006, 11:21 AM
Is there a difference in speed while using bluetooth and data cable ? As you guys have said ur bluetooth connection is showing slower speed as compaired to my CA 42 cable connection. I even use a low range model N 6070. IS THERE A SPEED DIFF BETWEEN DATA CABLE & BLUETOOTH WHEN USING GPRS ?
02-10-2006, 11:26 AM
AJJU
IR should increase speed (i think)but y u guys pay for it.Usin APNAZ trick its free .......iam browsin through that
I love and Live to Design
02-10-2006, 01:34 PM
Dude I get a download speed of 25kbps. Me using a nokia 6630.
02-10-2006, 07:26 PM
AJJU
hey xenon how do u get that speed!!!!!!!!!!! what connectivity tool do u use IR BLUETOOTH OR DATA CABLE and do u use AIRTEL or etc...
02-10-2006, 08:09 PM
That trick doesnt work with SE phones does it.!!
i hv SE W810i (Class 10 Edge)
I love walking in Rain ,because no-one knows i am Crying :|
02-10-2006, 10:45 PM
@ AZZU
wat speed do u get?
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
02-10-2006, 11:16 PM
t3h g04t
Im using 6681 with data cable and I get speeds upto 24 KiBps in Kolkata, Bluetooth will limit you to about 12-13 KiBps, IR is even slower but not available on this phone
technologically challenged.
02-10-2006, 11:24 PM
The Devil's Advocate
data cable will giv better speeds than bluetooth .....
http://beingmanan.com
03-10-2006, 01:34 AM
>25 KBps here .. on a 6681 with DKU2
03-10-2006, 10:29 AM
i get horrifying 480 kbps wid my n90
03-10-2006, 06:28 PM
#19 (permalink)
AJJU
hey DIPEN apnaz tricks works in all gprs and wap broser enaeld phones i get a speed of 2-4 kbps (shown on my DAP)and i also get the same speed usin MO(mobileoffice).
03-10-2006, 11:15 PM
#20 (permalink)
i get 24-26kbps at nite on MO
04-10-2006, 01:27 PM
#21 (permalink)
Do anybody have wireless internet like Tata Indicom or Reliance Rconnet? What download speed are you getting?
Kiran Kumar R
04-10-2006, 02:43 PM
#22 (permalink)
Mobile Addict
Can you tell me if there is an unlimited data download offer of Hutch. Also mention how much does it cost.
04-10-2006, 07:23 PM
#23 (permalink)
>>>>>Monkey Power<<<<<
I get around 9 - 12 kBps using Nokia 6681 and DKU-2 Cable while Blue tooth it reaches in the range of 7-9 kBps while downloading any file in opera. These download speeds are consistent after some initial period when the downloading speed shows upto 30 kBps.
btw
What is APNAZ trick ?
If you want to be happy, be.
04-10-2006, 07:29 PM
#24 (permalink)
Web Entrepreneur
I always get 16-26 kB/ps on AirTel EGPRS/EDGE (on Airtel MobileOffice) with my Nokia 6233... subscribed for the monthly pack.
04-10-2006, 07:49 PM
#25 (permalink)
What on earth is this APNAZ trick . Willl anyone explain?
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein
04-10-2006, 08:25 PM
#26 (permalink)
Dude do u use tradition Windows Dialup Connection or the one provided by Nokia software..
and does it matter..if u use any of those..coz am using SE W810i and i hav the software bt i use traditional one..
Which one do u use..!!
05-10-2006, 10:12 AM
#27 (permalink)
Gangsta
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
i m using 6681 and 6230i bt both limit to max 4 to 6kb with bluetooth ,can i get more speed
05-10-2006, 04:30 PM
#28 (permalink)
no idea abt 6681 but 6230i must give more speed..
6230i has Class 10 EDGE......
05-10-2006, 06:02 PM
#29 (permalink)
oh yeah...that mite be the problem..i didnt consider it..!!
05-10-2006, 08:09 PM
#30 (permalink)
>>>>>Monkey Power<<<<<
@Josan, I have 6681 and i have experienced that cable (DKU-2) give better performance than Blue tooth. You can try using cable.
BTW Nokia 6681 also has Class 10 EDGE, see here
And no one has explained till now, what is APNAZ trick
