Old 18-09-2006, 12:01 AM   #1 (permalink)
sourav's Avatar
Default Mp3's as ringtone in nokia 6600
I have a Nokia 6600, and I cannot have mp3's as my ringtones.
For having songs as my ringtones I ve to convert them to wave format which consumes a lot of my valuable memory of the phone.
Do I have any way to make mp3's as my ringtones....(any software or codec that will do the job.)
Please write the correct procedure to install such program n where to find the program.
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 18-09-2006, 12:23 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Mp3's as ringtone in nokia 6600
search 4 the wma.mp3 sis codec on google
Pathik is offline
Old 18-09-2006, 12:44 AM   #3 (permalink)
mobilegeek's Avatar
@sourav ohh yaar u are a old member .. just search .. i have answered so many questions on it.
ok I am tellin in short .. u want to save the memory space by converting to mp3 .. if I tell u u can even save double than that .. would u beleive me. yes u can.. Just install oggplay .. its freeware find on google.. u need oggplay-MMF_1.6.9.sis & use dbpower to convert to ogg format. use half bitrate than mp3. now use search u will find many threads.
mobilegeek is offline
Old 18-09-2006, 04:36 AM   #4 (permalink)
Google Bot
Pathik's Avatar
Pathik is offline
Old 18-09-2006, 03:18 PM   #5 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Is this oggplay application available in java format so tht it can be installed on S40 phones?
Also is there a java based MP3 player less thn 100KB?
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 18-09-2006, 04:35 PM   #6 (permalink)
mobilegeek's Avatar
for s40 .. no its not there
Site:http://symbianoggplay.sourceforge.net/
Old 19-09-2006, 04:35 AM   #7 (permalink)
sourav's Avatar
thanx to all, i have tried a lot of softwares to make ringtones work on my phone but noyhing worked. I have searched in digit, it said to use a codec but it also didn't work
sourav is offline
Old 19-09-2006, 03:27 PM   #8 (permalink)
The Devil's Advocate
iMav's Avatar
well if u r using 6600 then it should (no apparent reason as to y it wont on ur fone) ..... make sure u have a proper sis ..... rather than installing only the codec first try installing wmaplayer and if then u r able to set mp3s as ringtones then go for the codec ..... try you will succeed
http://beingmanan.com
iMav is offline
Old 22-09-2006, 03:27 AM   #9 (permalink)
mobilegeek's Avatar
Arrow Ogg files as ringtone in Nokia 6600 !!
havnt u got it done yet
.. ok i tell u the seedha seedha follow it, but dont ask many questions plz. just follow it
> uninstall the mp3/player if any already installed.(u can reinstall latter if u want)
> restart & install this(http://rapidshare.de/files/33969530/..._1_70.zip.html) in ur 6600
now install converter(1) & ogg vorbis codec(2) in your computer
right click the mp3 & wav files . select convert to and rip to ogg[at 24kbps 16000Hz Mono{dont use stereo}]
now copy these ogg files to memory card, delete all the wav & mp3 files stored in card
.. insert the card in phone if using card reader.
Go to profile n select .OGG file as ringtones. ogg codec is optimised for mobile devices & are half the size of mp3
Old 22-09-2006, 10:45 AM   #10 (permalink)
Why not to use Nokia PC Suite and convert MP3 to AMR instead.. file size just becomes 1/10.
enjoy is offline
Old 24-09-2006, 03:25 AM   #11 (permalink)
mobilegeek's Avatar
AMR sucks ... its for S40 mobiles which cant have mp3, .. quality of ogg/MP3 are much better
Old 24-09-2006, 10:43 AM   #12 (permalink)
Google Bot
Pathik's Avatar
yup.. Ogg is defi better than mp3.. Also u dont need a diff player 4 dat.. Ultra1.52 plays ogg 2
Pathik is offline
