Old 17-09-2006, 04:05 PM   #1 (permalink)
Mobile Addict
Smile NOKIA secret codes
If you think that these are helpful, pleaseee add to my reputation points.
__________________________________________________ _______________
Nokia Codes And Secrets
With Nokia codes or Nokia secret codes you can access hidden features and gain information about your Nokia phone. Many of the Nokia codes are only normally used by Nokia engineers. Nokiainfo.net takes no responsibility for any data loss resulting in using these Nokia codes.
Nokia code Code function:
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# This lets you know who called you last (Only vodofone)
*#1471# Last call (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#30# Lets you see the private number
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code press and hold # Lets you switch between lines.
aritrap is offline
Old 17-09-2006, 04:13 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: NOKIA secret codes
All this is pretty useful but sorry to say has been posted a lot of times before. If you'd have searched before posting you'd have found atleast dozen such 'special codes' threads.
Old 17-09-2006, 04:52 PM   #3 (permalink)
Official Techie's Avatar
and many do not work also in india and u just copy pasted it from net
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 17-09-2006, 05:36 PM   #4 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Always give the source from where u take the info.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 17-09-2006, 06:34 PM   #5 (permalink)
18 Till I Die............
Thread Closed. Just search this forum. It has been given here many times.
http://www.bash.org/?258908
mehulved is offline
