Old 17-09-2006, 01:40 PM   #1 (permalink)
Default use cellphone as webcam
hi i got a nokia 3230 cellph i wanted to kno is if there is anyway by which i can connect it to my laptop and use it as a webcam fer chatting n stufff.i connect d phone via bluetooth bt dunno ne software fer webcam option
pl reply
artem is offline
Old 17-09-2006, 01:50 PM   #2 (permalink)
readermaniax's Avatar
Thumbs up Re: use cellphone as webcam
Warelex Mobiola Webcam Usb V1.00 & V1.04 S60
Description:
Turn your Symbian phone into a high-quality USB-based web camera. Very simple to install and configure, Mobiola Web Camera 1.0 consists of two software components: (1) a client application that resides on the phone, and (2) a webcam PC driver compatible with any Windows application that can receive video feeds from a web camera including Skype 2.0, MSN and AIM. Carry your webcam with you wherever you go and connect it to your laptop at anytime. Try it now and experience resolution and frame rates comparable to some of the top-performing USB webcams on the market! UIQ and Series 60 with Bluetooth support versions are also available on Handango. Stay tuned Windows Mobile version...
(Click Below for the enlarged Details..)
Requirements
8 MB of free disk space on PC, 68kb of free phone memory, 720kb run time memory
Compatible Devices
Nokia 3230
Nokia 6260
Nokia 6620
Nokia 6630
Nokia 6670
Nokia 6680
Nokia 6681
Nokia 6682
Nokia 7610
N70
PM Me For How To GeT The Details!
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 17-09-2006, 02:51 PM   #3 (permalink)
keves2002's Avatar
Default Re: use cellphone as webcam
Is it possible to do the same with a Sony Erricson w810i ?
Tip: Save time by hitting the return key instead of clicking on "search"
keves2002 is offline
Old 17-09-2006, 03:15 PM   #4 (permalink)
Ishan's Avatar
& with sony erricson z550i?
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 17-09-2006, 08:29 PM   #5 (permalink)
dOm1naTOr's Avatar
&SE W700i?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 17-09-2006, 08:50 PM   #6 (permalink)
&SE W700i?
No .. The Softwares Support The Give Fonez only!
dunno if u can tweak it or nt
Old 05-03-2008, 07:57 PM   #7 (permalink)
I draw every day
yash's Avatar
go to http://motvik.com/ and download wwigo.
Kisne roba mera tobat.
yash is offline
Old 06-03-2008, 12:13 AM   #8 (permalink)
TooR
alok4best's Avatar
Mobiola is for Symbian Phones.
If ur fone runs on Symbian then u can sure use it.
I wish !!
alok4best is offline
Old 06-03-2008, 01:08 AM   #9 (permalink)
The Devil's Advocate
iMav's Avatar
wwigo +1 great app used it with 6600 over bluetooth on vista and xp and wrked gr8
http://beingmanan.com
iMav is offline
Old 06-03-2008, 03:23 PM   #10 (permalink)
ayush_chh's Avatar
nice sharing.....thanks.
will try now......i have N72......
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 06-03-2008, 03:28 PM   #11 (permalink)
Cool G5's Avatar
This won't work on firmware phones like SE.
It needs a phone having a Symbian OS.
Cool G5 is offline
Old 06-03-2008, 03:34 PM   #12 (permalink)
Sangeet Premi
2kewl's Avatar
S40 compatible?
2kewl is offline
Old 06-03-2008, 10:29 PM   #13 (permalink)
Cool G5's Avatar
^Nope.
Cool G5 is offline
Old 06-03-2008, 10:34 PM   #14 (permalink)
Still Shining!
Lucky_star's Avatar
wwigo is a java app, so it should run in both S40 and SE phones.
But its mentioned that on S60 V3 and V2 compatible. so only symbian
Nokia N86 8MP
Lucky_star is offline
Old 06-03-2008, 10:37 PM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Have Motorokr E6 and with just a click, I can use my phone as webcam (feature built in the OS itself, no extra tool required)
desiibond is offline
Old 07-03-2008, 10:07 PM   #16 (permalink)
I draw every day
yash's Avatar
motorokr E6 has that kind of facility? I never knew. does it also work on macs?
yash is offline
Old 07-03-2008, 11:43 PM   #17 (permalink)
Elevating Humanity
The Conqueror's Avatar
Mobiola is nice but it isnt free........
Wwigo seems good ... I have to search my bluetooth dongle now
Regards,
The Conqueror
The Conqueror is offline
Old 08-03-2008, 04:15 PM   #18 (permalink)
TooR
alok4best's Avatar
WWIGO didnt work on my IVT BLUESOLEIL bluetooth Dongle.
Mobiola works fine.
I wish !!
Old 08-03-2008, 08:24 PM   #19 (permalink)
Great tricks, thanks buddy. I have nokia n72.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 09-03-2008, 01:27 AM   #20 (permalink)
ayush_chh's Avatar
wow man its working........thanks a lot
Old 09-03-2008, 10:17 AM   #21 (permalink)
mekalodu
iinfi's Avatar
Cool Re: use cellphone as webcam
wont this wrk with data cable?? i dont v bluetooth on the pc...
mekalodu
iinfi is offline
Old 09-03-2008, 01:55 PM   #22 (permalink)
Still Shining!
Lucky_star's Avatar
^^What phone do you have?
Nokia N86 8MP
Old 09-03-2008, 03:22 PM   #23 (permalink)
mekalodu
iinfi's Avatar
n72 n n70
mekalodu
iinfi is offline
Old 09-03-2008, 05:59 PM   #24 (permalink)
expertno.1's Avatar
Best would be to use SmartCam , supports both symbian and s40 phones alongwith SE phones .
.sis files included for symbians and .jar for SE
but it requires BT plugged into your pc , its not USB .
Get it from here , direct link
http://prince.uk.to/attachments/3/10...rtCam_v1.2.rar
So happy viewing
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 09-03-2008, 08:09 PM   #25 (permalink)
Still Shining!
Lucky_star's Avatar
Originally Posted by iinfi View Post
n72 n n70
Search for Mobiola Web Camera 2.2 for S60 2nd Edition. Its for N70 and N72 and works through both bluetooth and USB.
Nokia N86 8MP
