Old 04-09-2006, 09:01 PM   #1 (permalink)
Smile Motorola SLVR L7
Hi guys,
I jus wanted to purchase a Motorola SLVR L7 in Chennai, but i have one doubt.
Does this phone have the iTunes software installed in it for playing music?
Please tell.
-Sai
sai_cool is offline
Old 04-09-2006, 09:27 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Motorola SLVR L7
No, the L7 does not support iTunes. For that you'll have to buy the Motorola RAZR V3i which has iTunes support. The L7 only has a basic mp3/aac player. Although you won't be needing the iTunes as the service is not yet launched in India.
Old 05-09-2006, 06:56 AM   #3 (permalink)
Red face Re: Motorola SLVR L7
Can we listen to music in the background and also send a message,or take a photo or do something in the menu?
-Sai
sai_cool is offline
Old 05-09-2006, 11:14 AM   #4 (permalink)
krazyfrog
Posts: n/a
Yes the L7's player also works in the background. You can do other things while listening to music. Although i don't think you can use the camera while listening to music. In most phones activating camera pauses the music.
Old 05-09-2006, 03:41 PM   #5 (permalink)
Smile Re: Motorola SLVR L7
Thanks a lot krazyfrog for clearing my doubts.
sai_cool is offline
Old 05-09-2006, 03:53 PM   #6 (permalink)
Anand_RF's Avatar
I own an L7. It doesn't support aac format or mp3s above 192 kbps bitrate. Mp3s at or below 192 kbps are supported. But the player doesnt work in background when using camera. Not a big deal this, though. Buy it if you can ignore the no-fm part. iTunes is really not needed IMO, the motorola digital player has a great deal of control. If you have any doubts, ask me.
Anand_RF is offline
Old 05-09-2006, 05:33 PM   #7 (permalink)
hi anand,
thanks for replying.
i jus wanna confirm one more thing again.
Can we type a sms or surf using GPRS while listening to music in the background.
And how do u rate the phone on a scale of 5.
Thnks.
-Sai
sai_cool is offline
Old 05-09-2006, 06:25 PM   #8 (permalink)
Anand_RF's Avatar
Yes you can type sms and use gprs while listening to music. As for rating the phone, I'd say 3.5 out of 5. -1 for no FM and - I don't know if it's a problem with my piece or all, but the signal reception is slightly on the weaker side. But you won't have this problem in chennai, I had full signal strength over there. But to be honest, this phone has no other problems, it's absolutely wonderful not to mention its super-slim. I don't think any other phone in the same price range offers the same amount of features AND beauty.
Anand_RF is offline
Old 05-09-2006, 07:43 PM   #9 (permalink)
Thanks for replying so soon anand. I owe u one.
I will be buying this phone next month.
Will tell u my experience later.
-sai
sai_cool is offline
Old 08-09-2006, 06:07 PM   #10 (permalink)
Hi anand,
jus have one more doubt,
can we transfer mp3's to the player without using the software and jus using windows?
where is the music player located in the menu?
Wat are the contents of the package?
Thnks again.
-Sai
sai_cool is offline
