Originally Posted by exx_2000
Hi all,
I have 2 phones. I previously used a Nokia 3230 and now I have a 6681. I liked one of the games on the phone, is there any way i can transfer that application to my 6681 using bluetooth or any other method? Also is this illegal?
Thanks in advance
exx_2000
You have just the 2 phones I got.
Simply install FExplorer, Enter it and rename the app file from *.sis to *.si (Just remove the last s or anything) and now via options send it via bluetooth and it'll automatically ask for install on the other phone.
I tried sending FExplorer.si from my FExplorer in 6681 to my Dad's 3230 and it worked fine, so will others.
If you're saying that you want to send an
installed file over BT, that isnt possible and will mostly lead to corruption due to the different versions. Better find it online for the newer phone and download it instead.
