Old 31-08-2006, 07:52 AM   #1 (permalink)
eagle_y2j's Avatar
Default How to get mobile !
I wanna use my laptop to surf internet on run (travelling) its has three conectivity options wifi, bluetooth, express card suggest me cheapest way to surf .
Registered LINUX USER #438929
eagle_y2j is offline
Old 31-08-2006, 09:12 AM   #2 (permalink)
sariq
Posts: n/a
Default Re: How to get mobile !
cheapest is bluetooth+gprs, good coverage, only problem is lower speed.
wifi will not be available while on run, you may find some hotspots. wifi is not widespread in india
Old 31-08-2006, 10:40 AM   #3 (permalink)
montsa007's Avatar
the free option is wi fi go to inorbit and connect to their wi fi and surf fukat
montsa007 is offline
Old 31-08-2006, 01:34 PM   #4 (permalink)
alltime.homie's Avatar
The best would be to connect via mobile... That'll give you 115 kbps, but pretty good.
Live for the moment... not tomorrow...
If you think I've helped you or you like me for some reason... don't thank me... add to my rep ! ;)
alltime.homie is offline
Old 01-09-2006, 05:10 AM   #5 (permalink)
eagle_y2j's Avatar
suggest me cheapesttttttttt cell fone for surfing
Old 01-09-2006, 07:51 AM   #6 (permalink)
Google Bot
Pathik's Avatar
ngage qd.. But the speeds wd suck wit bt + gprs.. 115.2 is jus the conn speed.
Pathik is offline
Old 01-09-2006, 07:54 AM   #7 (permalink)
Beneath The Eyelids
The Outsider's Avatar
nokia 3220 for class 6 edge and class 10 gprs (only cable)
bought it for 4750 exact 2 weeks ago.
The Outsider is offline
