Old 30-08-2006, 03:56 PM   #1 (permalink)
linardni's Avatar
Default What Bluetooth Dongle???
Plz recommend any make of Bluetooth dongle to connect my Nokia 6630 with PC. Plz mention the price of it also.
linardni is offline
Old 30-08-2006, 04:03 PM   #2 (permalink)
manu1991's Avatar
Default Re: What Bluetooth Dongle???
I would recommend the X-Micro Bluetooth USB Dongle which retails for around Rs. 900/- (Class I - 100 Mts.) you can also opt for Class 2 (20 meters range) or Class 3 (10 meters range) Dongles which may be cheaper .
Winning is not everything , It is the only thing .
manu1991 is offline
Old 30-08-2006, 04:07 PM   #3 (permalink)
Alfansey06's Avatar
i have - - - class unknown, Rs.300/- works fine.
Alfansey06 is offline
Old 30-08-2006, 05:02 PM   #4 (permalink)
The Devil's Advocate
iMav's Avatar
buy a 100mtr dongle i got mine for 730/- (billionton)
http://beingmanan.com
iMav is offline
Old 30-08-2006, 05:53 PM   #5 (permalink)
what is the data transfer rate when we use bluetooth dongle?
are these dongles better than data cable??
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 30-08-2006, 05:54 PM   #6 (permalink)
Google Bot
Pathik's Avatar
get a bluesoliel for 250 rs....
Pathik is offline
Old 30-08-2006, 06:10 PM   #7 (permalink)
Alfansey06's Avatar
Data transfer rate depends on phone. {BT maxm. transfer rate is ~100KBps (800kbps)}- how fast phone can read/write in memory. while reading from phone memory by s40 phone speed will be ~60KBps. similar conditions in s60 ~20KBps. for transfering to MMC speed will be half in both cases.
Old 30-08-2006, 07:38 PM   #8 (permalink)
mAYHEM's Avatar
Got Orchid Bluetooth Dongle v1.2/v2.0 (ISSC Chipset) for Rs 300.Getting Avg 10KBps/USB 1.1 and Avg 25 KBps/USB 2.0 on N3230.Got Avg 75 KBps/USB 1.1 on N3250 all while transfering to MMC.So the USB revision and Bluetooth revision of phone and dongle r important.
Lenovo Y570|eMachines EM350|iPad2 (3G)|iPod (80GB & 160 GB) |Galaxy S2|Galaxy Note|Storm 9500|Nokia 8800|Shure SE535|Sennheiser CX 500.
http://www.speedtest.net/result/445135884.png
mAYHEM is offline
Old 07-09-2006, 06:19 PM   #9 (permalink)
linardni's Avatar
I have procured a Bluesoliel make. However I am having one way connection only...transferring data from mobile to PC but not the opposite. Whenever I am trying to gain access to the mobile through PC Suite installed in my PC, the connection wizard stops after identification of the only available bluesoliel stack. Plz note I don't have Windows XP Service Packs installed. Is it for that? Plz help.
linardni is offline
Old 07-09-2006, 09:54 PM   #10 (permalink)
Google Bot
Pathik's Avatar
wich dongle did u take.. Use its drivers
Pathik is offline
Old 08-09-2006, 08:28 AM   #11 (permalink)
iMav's Avatar
ok here is 1 problem i am facing .... the mrouter in the system tray shows that the fone is connected (it changes its color to green and blue) ... but wen i run pc suite it says not connected workin offline .... any suggestions.....
iMav is offline
Old 29-07-2009, 06:26 PM   #12 (permalink)
tHe nEw gEEk......ITian
pr.itdude's Avatar
Lightbulb Re: What Bluetooth Dongle???
digging this old thread..........
can anyone tell me a bluetooth dongle, must have support for a2dp,
actually i want to connect my stereo bluetooth headset to pc....!!!
need ans asap.........thnx guyz.....!!!
pr.itdude is offline
