Old 30-08-2006, 01:40 PM   #1 (permalink)
tuxfan's Avatar
Default Need entry level cell phones
I need to buy 2 handsets for the office staff. They are likely to be used roughly.
Can anyone please suggest some entry level rough-n-tough GSM handset? I don't want to spend too much on this.
Thanks.
tuxfan is offline
Old 30-08-2006, 02:10 PM   #2 (permalink)
alltime.homie's Avatar
Default Re: Need entry level cell phones
Depends. Do you wanna go for non color or color ? If you wanna go for non color, then the best would be the Nokia 1100. As for color, it also depends. You could go for the Samsung X200, the SE K310i, or even the 6030 or 3220. These are all pretty good. Though wait for more suggestions
Live for the moment... not tomorrow...
If you think I've helped you or you like me for some reason... don't thank me... add to my rep ! ;)
alltime.homie is offline
Old 30-08-2006, 02:13 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Go for Motorola's C115 (not sure on the model). It's less than 30$. That's the cheapest GSM phone. Quite sturdy as well.
drgrudge is offline
Old 30-08-2006, 02:51 PM   #4 (permalink)
Alfansey06's Avatar
nokia 1100. rough and tough, entry level GSM phone
Alfansey06 is offline
Old 30-08-2006, 06:15 PM   #5 (permalink)
hey
go 4 nokia 1108. the screen display is better than nokia 1100. for color phones go 4 nokia 2600.
sarandigit is offline
Old 30-08-2006, 06:29 PM   #6 (permalink)
Google Bot
Pathik's Avatar
yup nokia 1100 or 1108 r good.... MADE FOR INDIA
Pathik is offline
Old 30-08-2006, 07:32 PM   #7 (permalink)
tuxfan's Avatar
Thanks guys I don't want colour screen or any add-ons. They should be simply able to receive my calls Don't even need SMS
tuxfan is offline
Old 30-08-2006, 07:45 PM   #8 (permalink)
shashank4u's Avatar
i think u shud give them indicom..too cheap and free incoming...
so yr staff dont have to recharge..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 30-08-2006, 08:11 PM   #9 (permalink)
18 Till I Die............
I'd say Nokia. Cos the build quality of Nokia has been better than other manufacturer's IMO.
http://www.bash.org/?258908
mehulved is offline
Old 30-08-2006, 08:35 PM   #10 (permalink)
Commander in Chief
QwertyManiac's Avatar
+1 for the 1100 damn sturdy too
Harsh J
www.harshj.com
QwertyManiac is offline
Old 30-08-2006, 08:41 PM   #11 (permalink)
Well, no fancy - that means a 1100 will do. Very good and very useful.
Old 30-08-2006, 09:45 PM   #12 (permalink)
drgrudge's Avatar
Moto costs less than 1.5k bucks. It's cheaper than 1100. When you buy 2 phones, moto is a good choice. If you're gonna use for a long time, you need not even think of exchanges and stuffs. Moto is perfect. I think it costs around $30 only.
drgrudge is offline
Old 30-08-2006, 10:08 PM   #13 (permalink)
Google Bot
Pathik's Avatar
wat does a new 1100 cost.. Abt 1.6k.. Nd 2nd hand abt 1k... Isnt dat cheap..
Pathik is offline
Old 31-08-2006, 02:09 AM   #14 (permalink)
Beneath The Eyelids
The Outsider's Avatar
how bout nokia 3315 lolz
The Outsider is offline
Old 31-08-2006, 01:17 PM   #15 (permalink)
tuxfan's Avatar
Thanks guys for your opinions.
I will surely have a look at the entry level moto and N1100. Any models from SonyEriccon?
N3315 is out of question as manufacturing is stopped since long. I don't want second hand handsets. And actually, that is the one that I am replacing
tuxfan is offline
Old 31-08-2006, 04:51 PM   #16 (permalink)
Mr. S Nova
supernova's Avatar
Rough + tough + cheap + good = N 1100
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 01-09-2006, 03:35 PM   #17 (permalink)
csczero's Avatar
1112 will do as it has WHITE display instead of green or blue as in case of 1100 (looks cheap)
DELL 1500 Vostro , Playstation 3, LG LD460 42" , Nokia E5
csczero is offline
Old 01-09-2006, 07:10 PM   #18 (permalink)
Tech'ing life seriously!!
sude's Avatar
me vote for nok1108... the best and sturdy handset available in market today...
<i have nok1108 and it had been under 4wheeler vehicle twice but no serious injury only minor scratches>>> m using still.
go for nok1108...
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 01-09-2006, 07:13 PM   #19 (permalink)
The Devil's Advocate
iMav's Avatar
well the thing with nokia fones (gsm fones) is that the connection charges are too high and tricky hence i wud suggest either reliance or tata
http://beingmanan.com
iMav is offline
Old 01-09-2006, 08:01 PM   #20 (permalink)
Commander in Chief
go for nok1108...
-SUDE
Was that some stress test? how the hell did it come under a vehicle?
Harsh J
www.harshj.com
Old 01-09-2006, 09:00 PM   #21 (permalink)
My old Nokia 3350 had gone under the wheels of two cars and a bus but came through it with nothing more than just scratches.
mehulved is offline
