Old 26-08-2006, 10:39 PM   #1 (permalink)
Default wireless lan
After lot of confusions and dilemma . i bought a compaq v5201ut laptop which has wireless lan built in , now want to connect it to my desktop pc wirelessly to share internet and other resources . what is the simplest and cost effective way ?
Dont die of ignorance .
digitizen is offline
Old 26-08-2006, 11:05 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: wireless lan
take a wifi adapter for ur pc.....
but the cheapest way is a lan cable...
Pathik is offline
Old 26-08-2006, 11:56 PM   #3 (permalink)
i know the cheapest is a lan cable . but i want wireless network . by the way can i simply buy a wireless access point instead of a router.
Old 27-08-2006, 01:20 AM   #4 (permalink)
The Devil's Advocate
iMav's Avatar
for conx between 2 pcs u can directly connect them this is the ad-hoc mode .... 2 wi-fi adapters required and u can configure them
http://beingmanan.com
iMav is offline
Old 27-08-2006, 08:56 AM   #5 (permalink)
so do i have to bbuy onemore cause i already have a wireless equipped laptop
Old 27-08-2006, 09:00 AM   #6 (permalink)
D PrankMaster
prankie's Avatar
hey, i have 2 Wifi enabled laptops.. i wanna transfer data between them.. how to do that??? none of the lappy detects other!!!, when i try to search for wireless networks...
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 27-08-2006, 02:19 PM   #7 (permalink)
iMav's Avatar
humm... i do not know wat could be the problem ..... but make sure that the protocols are the same (The ‘g’ & ‘b’ standards are compatible with each other as their operating frequencies are same) .....
@digitizen u will hav to buy another wi-fi adapter for ur desktop .....
iMav is offline
