Old 22-08-2006, 09:44 PM   #1 (permalink)
True Techie
nithinks's Avatar
Question which one is better
i just want to know that from the following which one is the best one:-
k750i - Sony Ericcson
w700i - "
6233 - Nokia
i hope that i will get the result as soon as possible
http://www.mytechyard.com/
nithinks is offline
Old 23-08-2006, 01:52 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: which one is better
Wrong Thread Dude....special Thread For Mobile Queries
MY VERDICT : K750i
wizrulz is offline
Old 23-08-2006, 10:42 PM   #3 (permalink)
rajwansh2003's Avatar
750i is best all around in its range
Anupam
rajwansh2003 is offline
Old 24-08-2006, 01:33 AM   #4 (permalink)
Tech.Masti's Avatar
it depends on how you use the phone.
if you want for mainly camera & music, then go for SE .., and if you using this phone for mainly internet access and others simple purposes 6233 is the best...
i prefer nokia 6233 because it's
1. it's 3G man, be futureproof...
2. it has class 10 EDGE, that means you can use your phone as modem in good speed.
3. it has stereo speakers with 3D effects
4. 240x320 display
but it also lacks some features,
-no front camera
-no flash for camera
-radio is not RDS
-only 6MB internal memory
check features of 6233 and w700i
http://www.gsmarena.com/com<br /> pa...&idPhone1=1527
Tech.Masti is offline
Old 24-08-2006, 02:33 AM   #5 (permalink)
Official Techie's Avatar
go for 6233 its newer than k750i but i wonder if the cam quality will be better or not
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 24-08-2006, 10:29 AM   #6 (permalink)
Sambit_Lucky's Avatar
I think K750i is the best phone.Check its features that is great!
Sambit(*_*)
The Man Who Always Helps Others.
Sambit_Lucky is offline
Old 27-08-2006, 05:45 PM   #7 (permalink)
Cool G5's Avatar
K750i is the best for 14k.Sony also bundles a 512 mb memory card with it.
Cool G5 is offline
Old 27-08-2006, 06:24 PM   #8 (permalink)
Google Bot
Pathik's Avatar
k750i for me....
Pathik is offline
Old 29-08-2006, 01:59 AM   #9 (permalink)
csczero's Avatar
w700 as walkman series i would have gone for nokia 6233 but it is a non smart phone
csczero is offline
Old 06-09-2006, 05:24 PM   #10 (permalink)
Cool G5 ...r u sure sony provide 512 MB mem stick with K750i as the specs says it has 64 Mb +38 MB(intrenal)
chits is offline
