Old 21-08-2006, 03:05 PM   #1 (permalink)
Question Help:GPRS using Nokia 6030
hi
i have Nokia 6030
i activate Airtel GPRS from my mobile, i can access sites using mobile browser.
can i access internet from my PC using 6030,
Is 6030 act as modem like 6600,
i bye data cable, but i don't know how to connect it?
pls help me.
amolwable is offline
Old 21-08-2006, 04:38 PM   #2 (permalink)
Beneath The Eyelids
The Outsider's Avatar
Default Re: Help:GPRS using Nokia 6030
not sure if it has inbuilt modem, you can check
on your phone go to Main menu>settings, if you see the the "Connectivity" tab there means it has a modem.
The Outsider is offline
Old 21-08-2006, 05:17 PM   #3 (permalink)
Google Bot
Pathik's Avatar
dunno abt cable... but u can do it thru BT...
nd wich version of pc suite do u hav... try 6.8xx .. it may work..
Pathik is offline
Old 21-08-2006, 11:46 PM   #4 (permalink)
Tech.Masti's Avatar
6030 has no BT, IR only data cable... and i guess it has no modem also
Tech.Masti is offline
Old 21-08-2006, 11:57 PM   #5 (permalink)
rajwansh2003's Avatar
No you can acess it. From which network are you using it?
the problem is that the connectivity of gprs is bit diff. in 6030. all problem come due to com port. first check in device manager that your mobile port is not in com1 and make one modem from control panel phone and modem option.
note while connecting your cell to net do not connet ur cell to pc suite.
Last edited by rajwansh2003; 22-08-2006 at 12:06 AM. Reason: Automerged Doublepost
rajwansh2003 is offline
Old 22-08-2006, 11:05 AM   #6 (permalink)
You have to install Nokia PC Suite 6.x . download from nokia website . After installing the Software let it detect ur phone either by ir or data cable and then from main menu of the pc suite cilck connect to the internet. Select settings and either select ur network or enter the settings manually. Click connect and there u go.
honey62022 is offline
