Old 20-08-2006, 02:05 PM   #1 (permalink)
Unhappy Query regarding 3230
I surf through Airtel GPRS on my PC via data cabel.
First time when i connect my mobile to the pc through data cabel the modem is detected,but if i disconnect the data cabel and again connect it, during dialing it gives an error saying hardware not found.
So every time i have to restart the mobile and then connect to the pc,is there any other metod to do it because every time i have to restart the mobile.....which may decrease my battery life........
ash24 is offline
Old 20-08-2006, 02:12 PM   #2 (permalink)
Beneath The Eyelids
The Outsider's Avatar
Default Re: Query regarding 3230
make sure the data call is ended on the phone before you plug out the cable (the phone says "Packet Data Call Ended")
not sure if 3230 shows that message.
second thing
plug in the cable properly, to assure that check the phone it will give a message like "Data Enhancement Connected"
hope this helps.
The Outsider is offline
Old 21-08-2006, 08:19 PM   #3 (permalink)
Post Re: Query regarding 3230
@chester
thanks....i will try it
is there any firmware upgrade for 3230....because its OS is too slow ya...?
ash24 is offline
Old 21-08-2006, 08:23 PM   #4 (permalink)
sariq
Posts: n/a
Use bluetooth, it works without any hassles, and you dont require pc suit for that.
Old 21-08-2006, 08:32 PM   #5 (permalink)
ya iam thinking of using bluetooth.....are there different types of bluetooth that is based on the speed and what are there cost?
ash24 is offline
Old 22-08-2006, 10:59 AM   #6 (permalink)
There r two types of bluetooth . 1 from Widcomm and other from Bluesoleil which sucks.
Widcomm is little expensive and offers wide range of connectivity options. Comes along with Techcom. Around 400rs.
Bluesoleil is cheap around 200rs. less useful and user interface is a pain to learn and very complicated.
honey62022 is offline
Old 22-08-2006, 08:06 PM   #7 (permalink)
can i upgrade it as my mobile is in warranty period......?
ash24 is offline
