Old 15-08-2006, 11:02 AM   #1 (permalink)
ayush_chh's Avatar
Default Nokia 6030 vs Motorola c168
hi there!
i want to buy a cell phone my budget is 2500-3500....i hav selected these two mobile with same features....can ny 1 help me in selecting one out of these two? please suggest any other model also......(req: color disp. with FM)
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 15-08-2006, 12:40 PM   #2 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Default Re: Nokia 6030 vs Motorola c168
u cud also try out the newly released 2310 frm nokia but i wud suggest not going for it coz it has a small screen and also despite having 4mb memory u cant dwnld wallpapers.
go for 6030.
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 15-08-2006, 10:21 PM   #3 (permalink)
ayush_chh's Avatar
thanks man.....but the price for 6030 exeeds my budget....that's why i am looking for alternatives......if not available then i will surely go 4 6030
Old 15-08-2006, 10:35 PM   #4 (permalink)
18 Till I Die............
Very bad. Posting in wrong section after being a member for so long.
http://www.bash.org/?258908
mehulved is offline
Old 16-08-2006, 12:08 AM   #5 (permalink)
Tech.Masti's Avatar
motorola c168 battery is 1000mah. so listen radio for long time.
Nokia 6030 is 65k display screen, in MOTO its 4k.
Nokia has more memory, can't remember, but its more than 1mb., and MOTO has 600kB. Actually here a lot price difference, around 1k. if you need a minimum phone(minimum.........), then minimum phone is c168.
Also in market,Samsung c230, lg 2070, SE j230i are also low budget radio phone. i mean about radio+GPRS phone......now think yourself....
Tech.Masti is offline
Old 16-08-2006, 09:34 AM   #6 (permalink)
ayush_chh's Avatar
sorry !
my first posting on mobile......and i thought if i put it in QnA segment i will get good response...
Old 17-08-2006, 02:00 PM   #7 (permalink)
rajwansh2003's Avatar
Talking Re: Nokia 6030 vs Motorola c168
man go for 6030 look good speaker is cool one and colour display in clear with 65k and with gprs which is easy to use.battry will at least work for 2+ days. i think you don't live in village so u require more battry backup. massage capacity is large and connectvity is well. more over digit has given it best silver bye. if you can bye Ipod why can't you spend 4,000. go for it.
tell your papa about n93
N93 Battery Life
Standard Li-Ion Battery 1100 mAh
-- Digital Talk Time up to 5.1 hours*
-- Digital Standby Time up to 10 days*
Specifications
Weight: 6.35 ounces
Dimensions: 4.65 x 2.19 x 1.11 inches
Nokia N93 Sales Package Contents
128 MB miniSD card MU-17*
Nokia Battery BP-6M
Nokia Stereo Headset HS-23
Nokia Travel Charger AC-4
Nokia Charger Adapter CA-44
Nokia Connectivity Cable CA-53
Nokia Video Connectivity Cable CA-64U
Protective Pouch CP-83
Wrist Strap CP-84
DVD-ROM with PC software - (containing Nokia PC Suite, Lifeblog, Adobe Photoshop Album Starter Edition, Adobe Premiere Elements 2.0, Home Media Server software)
User guide, Quick Start guide, Get Connected guide and Add-on Application guide
Display and User Interface
Internal Display:
320 x 240 pixels, up to 262,144 colors
Active matrix 2.4" QVGA color screen
Wide 160° viewing angle
Automatic brightness control
External Display:
Large 1.1" screen
128 x 36 pixels, up to 65,536 colors
Twist and Shoot form factor
4 modes:
Imaging mode for capture
View mode for reliving memories
Fold open mode for talking
Fold closed mode for carrying
3.2 megapixel (2048 x 1536 pixels) camera, Carl Zeiss Vario-Tessar lens, 3x optical zoomDirect connection to compatible TV via Nokia Video Connectivity Cable (CA-64U, included in box) or wireless LAN/UPnP19
Sub camera, CIF (352 x 288) sensor
Integrated flash (operating range up to 1.5m)
Flash modes: on, off, automatic
Still image file format: JPEG/EXIF
Auto focus/Auto exposure - center weighted
Exposure compensation: +1 ~ -1EV at 0.5 step
Focal length 4.5 mm (Wide) /12.4 mm (Tele) 34.25 - 94.1 mm (35mm equiv.)
Focus range 10 cm ~ infinity
rajwansh2003 is offline
Old 17-08-2006, 02:47 PM   #8 (permalink)
Anand_RF's Avatar
Where did that come from? He said his budget was 2500-3500, not 25000-35000.
@poster: Go for 6030. It suits you better than c168.
Anand_RF is offline
Old 17-08-2006, 06:23 PM   #9 (permalink)
Tech'ing life seriously!!
sude's Avatar
go definitely for nok6030. i am using one its flawless. great for for it without any other thought... but if u are concerned abt fm quality then motorola 168 quality is much better than 6030. but that does not change ur decision... isnt it...??
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 18-08-2006, 12:46 PM   #10 (permalink)
Mr. S Nova
supernova's Avatar
C168 will come for 2.8k ... well in your budget (good battery, gr8 FM quality)
If you want Nokia go for 2310 for just above 3k.. still in your budget
I dont see a point in spending another 1k on 6030.
chk out features of all above models on www.indiagsm.com
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 20-08-2006, 09:22 PM   #11 (permalink)
ayush_chh's Avatar
@ supernova
thanks man.................followed ur reply .......bought c168 for Rs2700 and a silver coin as gift
bought frm kolkata.......the price was really cool
Old 21-08-2006, 01:43 AM   #12 (permalink)
Tech.Masti's Avatar
i am not sure about datacable support and inbuild modem of c168, please tell me...
Old 21-08-2006, 12:26 PM   #13 (permalink)
Mr. S Nova
supernova's Avatar
Originally Posted by ayush_chh
@ supernova
You are welcome dude... addn a lil bit to repu would not harm
Old 06-10-2006, 10:43 AM   #14 (permalink)
man go for nokia 6030 only for rs 3800 only
Anupam
Old 07-10-2006, 09:30 PM   #15 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
hy man u must try for a nokia 2nd hand phone
Josan is offline
