Old 14-08-2006, 05:31 PM   #1 (permalink)
Default W810i
Hi all
Can somebody tell me if it is possible for W810i to be able to write Text messages thru my PC when the phone is connect to PC with USB cable of Bluetooth.
Thanks
harmads is offline
Old 15-08-2006, 01:29 AM   #2 (permalink)
sting's Avatar
Default Re: W810i
yes , use software's like MyPhoneExplorer or FMA
sting is offline
Old 17-08-2006, 04:00 PM   #3 (permalink)
Default Re: W810i
Thanks sting for your reply.
I have a problem with MyPhoneExplorer. I hope you will help me in that. MPE does not identify my phone. I am using XP. I have tried various but failed. If you could give me a step wise guideline I will be grateful.
Thanks
harmads is offline
Old 17-08-2006, 05:09 PM   #4 (permalink)
sting's Avatar
Default Re: W810i
ya y not, just turn on the BT and pair with ur phone, open the MPE->Option->connection and apply this settings
Port : 21 ( default)
Budrate : 9600 thats it , it will work, reply here if its works or not
for BT
for USB
( dont forget to connect the BT using any BT software like BlueSoleil )
sting is offline
Old 26-08-2006, 11:51 PM   #5 (permalink)
arjun2040's Avatar
Default Re: W810i
you can use the SonyEricsson PC suite itself to do that
install it, connect the cable, let the pc detect ur fone and then in the main window, click on communication center
voila! all your msgs can be viewed and u can also send 'em
cheers!
arjun2040 is offline
