Old 14-08-2006, 01:12 PM   #1 (permalink)
Default Please help ME.........
Hi Folks....
I have been using Nokia 3230 and water went inside the phone...Service centre said that they cant repair and no solution for this..... can some one suggest me on this.... Please
Thanks
Saran
sarvanan is offline
Old 14-08-2006, 01:46 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Please help ME.........
sorry d00d thats a hardware problem... if service centre cant do nething.... then how can we???
Pathik is offline
Old 14-08-2006, 02:15 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Once I faced the same problem with Nokia 3120.
I just opened the phone, removed battery and otehr parts and placed it outside my house to give it some sunshine!
After a few hours, it was working fine!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-08-2006, 04:48 PM   #4 (permalink)
D PrankMaster
prankie's Avatar
yup, thats the last thing u can do...
best of luck
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 14-08-2006, 04:52 PM   #5 (permalink)
All my contact are saved in the phone memory...is there any way to take that ???
sarvanan is offline
Old 14-08-2006, 05:11 PM   #6 (permalink)
Google Bot
Pathik's Avatar
arey if ur fone is saved then its a big thing.... n u want ur contacts :-P
Pathik is offline
Old 14-08-2006, 05:48 PM   #7 (permalink)
which is the next good model available ..... on the same or + feautres. with 15k budget
sarvanan is offline
Old 14-08-2006, 06:11 PM   #8 (permalink)
D PrankMaster
prankie's Avatar
U already being a smartphoneuser... should consider following models
Nokia 6680, Nokia 3250 (slightly over ur budget), Nokia N70 (~16.5k)
Old 14-08-2006, 06:18 PM   #9 (permalink)
Google Bot
Pathik's Avatar
hmm... if u can increase ur budget to abt 17k then n70...
Pathik is offline
Old 14-08-2006, 07:41 PM   #10 (permalink)
Official Techie's Avatar
go for 3250 good sound and good screen or u culd also go for se w800i
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 16-08-2006, 01:23 PM   #11 (permalink)
but folks i was using media card 512mb - for 3230 (i bought for Rs.2300) which are the other models ..i can use the same card ??? please advice.. whats the price of N72 and howz is it??
sarvanan is offline
Old 16-08-2006, 01:45 PM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes, RS-MMC will be supported by most. Though 3250 has these micro stuff instead :-s
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-08-2006, 01:51 PM   #13 (permalink)
Google Bot
Pathik's Avatar
yup u can use that rs mmc in almost all new cells.... and the n72 mite be arnd 20k
Pathik is offline
Old 16-08-2006, 03:06 PM   #14 (permalink)
what are the update/extra feautres available in N70 compare to 3230, whats the extact price now? any other phone is good in N series... please suggest me
sarvanan is offline
Old 16-08-2006, 05:57 PM   #15 (permalink)
Google Bot
Pathik's Avatar
n70 is the cheapest n series fone and a good one.....
it has 3g, os8.1 (3230 is os7).. the sound quality is better...
u can check the features of both @ gsmarena.com
Pathik is offline
Old 16-08-2006, 10:03 PM   #16 (permalink)
D PrankMaster
prankie's Avatar
Well i dunno why nokia people call it the "N" series... AFAIK features (excludin hardwareones) depend on the OS.. then why Nokia 3250 is not in Nseries and N73 or N91 which also have same symbian version in Nseries...
Old 18-08-2006, 09:11 AM   #17 (permalink)
Hey what's difference between N70 & N72 ????? and what is the price ...any idea as. . i am planning to buy off this week end. please suggest me.. thanks also my 3230 memory card will suit these phones right ??
sarvanan is offline
Old 18-08-2006, 10:32 AM   #18 (permalink)
D PrankMaster
prankie's Avatar
N72 is a non3G phone.. so it does'nt has a front camera... thats the only difference between the two...
Old 18-08-2006, 11:00 AM   #19 (permalink)
Hey whats is the difference of 3G phone ..as i am not aware...which one is worth buying ??????
sarvanan is offline
Old 18-08-2006, 11:53 AM   #20 (permalink)
D PrankMaster
prankie's Avatar
Third Generation–the next generation of wireless technology beyond personal communications services. The World Administrative Radio Conference assigned 230 megahertz of spectrum at 2 GHz for multimedia 3G networks. These networks must be able to transmit wireless data at 144 kilobits per second at mobile user speeds, 384 KBPS at pedestrian user speeds and 2 megabits per second in fixed locations. ...
in simple words if ur phone supports 3G, than in future (i dunno when!!) ur phone can be used for accesing high speed internet, and for applications like videoconfrencing ( front camera is for that purpose only) which require huge banwidth... currently india does'nt have 3G networks but in future, maybe 3months or 1year or 2year it'll have one..
till then 3G is useless...
Old 18-08-2006, 02:54 PM   #21 (permalink)
Google Bot
Pathik's Avatar
yup... n the cheapest 3g fone is 6630... nd a good one is n70.... but u shd wait for n73
Pathik is offline
Old 18-08-2006, 04:36 PM   #22 (permalink)
hey thanks man.....i thing i can go for N72... what say ...???
sarvanan is offline
Old 18-08-2006, 05:21 PM   #23 (permalink)
D PrankMaster
prankie's Avatar
ya sure!! its a very good phone...
Old 21-08-2006, 01:01 PM   #24 (permalink)
howz motorolla V3i ????? is it worth buying?????
sarvanan is offline
Old 21-08-2006, 04:15 PM   #25 (permalink)
D PrankMaster
prankie's Avatar
Gofor MOTO if u wanna flaunt it.... thats it!! but nowdays u cannot even flaunt it coz it has become too common...
abt the phone, its UI sux!!, camera qlty is avg. ,Music playback is above average... screen is bright and crisp..
Old 21-08-2006, 05:02 PM   #26 (permalink)
thanks prank.......have decided to go for N70....Can some one from bangalore tel me whats is the current price of N70...... Please....
sarvanan is offline
Old 21-08-2006, 05:11 PM   #27 (permalink)
Google Bot
Pathik's Avatar
kool.... good choice... u caN GET THE N70 FOR ARND 18K...
Pathik is offline
Old 21-08-2006, 07:35 PM   #28 (permalink)
Searching...
@sarvanan
Can you pls edit and give suitable title to you topic ???!!
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 28-08-2006, 09:05 AM   #29 (permalink)
Default Re: Thanks pathi & prank
Hey Pathiks & Prankie..........
I bought N70............... thanks for your sugges. its super.........b
Regards
Saravanan
sarvanan is offline
Old 28-08-2006, 03:56 PM   #30 (permalink)
Google Bot
Pathik's Avatar
kooooollll.. U tuk it 4 how much?
Pathik is offline
