Old 14-08-2006, 02:19 AM   #1 (permalink)
Tech.Masti's Avatar
Default == FM Radio ==
Anyone please tell me that is 3230 radio is mono or stereo? is it possible to install any software on 6630 to listen radio?( i think it's not possible)
Tech.Masti is offline
Old 14-08-2006, 02:51 AM   #2 (permalink)
Default Re: == FM Radio ==
well 3230 radio is stereo and u can install apps for ur radio in nokia 6630 but it will run wid gprs and it will cost more..presently
better use a fmradio headset (nokia original),and u can use this one wid nokia 6630
it will cost ur around 1000-1200bucks but its worth it !!
neerajvohra is offline
Old 14-08-2006, 10:14 AM   #3 (permalink)
Google Bot
Pathik's Avatar
@ techmasti for radio on 6630
u can use
virgin radio
virtual radio
spod radio etc
but u need gprs for that...
Pathik is offline
Old 15-08-2006, 02:09 AM   #4 (permalink)
Smile Re: == FM Radio ==
With a FM RADIO HEADSEt,can v listen to fm radio.....???
I have 6630. .So plz tell.. How much wil a duplicate cost...
Thanks
swades is offline
Old 15-08-2006, 09:32 AM   #5 (permalink)
D PrankMaster
prankie's Avatar
FM radio reciever (as the name suggest) is just like an antenna... it just catches the radio waves.. so it wont add any kind of radio stuff in ur non-radio phone..
FM radio is a hardware oriented feature so no software can add this feature to ur phone...
but if u wanna listen to online radio (via gprs) then there are many softwares like.
Originally Posted by pathiks
virgin radio
virtual radio
spod radio etc
My Rig: AMD Phenom II 550BE | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 15-08-2006, 09:46 AM   #6 (permalink)
Alfansey06's Avatar
Gprs radio have poor quality as data rate is limited, frequent pauses assciated with network problems and rapid battey discharge.
Alfansey06 is offline
Old 15-08-2006, 10:43 AM   #7 (permalink)
Google Bot
Pathik's Avatar
yup dats true..... u ll buffer more than u ll hear...
Pathik is offline
Old 15-08-2006, 03:07 PM   #8 (permalink)
Question Re: == FM Radio ==
I have some questions:--
So shud i buy a FM RADIO HEADSET for my 6630..
Will it b useful 2 me.. Will i b able to hear all the radio channels evn though their is no software or inbuilt radio in 6630..???
How much will an original one as well as duplicate cost..??
And whats the difference between the two...
I m very confused...
Thanks
swades is offline
Old 15-08-2006, 03:17 PM   #9 (permalink)
Google Bot
Pathik's Avatar
the fm radio headset is jus like those cheap fm available in the market......
its not actually attached to ur cell... u ll need separate batteries 4 dat
Pathik is offline
Old 15-08-2006, 04:42 PM   #10 (permalink)
Hey how abt a NOKIA RADIO HEADSET HS - 2R.. Came to know abt this frm the nokia site..
Will it work wid my nokia 6630... Is it available now???
Do reply....
swades is offline
Old 16-08-2006, 06:11 PM   #11 (permalink)
well for more info of nokia fm headset
visit here
h**p://www.nokia.com.sg/nokia/0,,55991,00.html
and its worth buying....it can control ur music player and ur fm from the headset itself...it had a button to start ur music player or fm..and thts gud
it supports stereo sound in both fm and music player
