Old 08-08-2006, 06:29 PM   #1 (permalink)
Stay Silent!
enticer86's Avatar
Default using PC Internet on cell
hey another query..can we somehow connect the cell to internet enabled PC thru BT so as to use GPRS on cell widout actually having gprs? i mean surfin the internet on cell tht way....wotsay my dear mods?
enticer86 is offline
Old 08-08-2006, 06:42 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: using PC Internet on cell
yup u can ..... u jus need gnubox...
Pathik is offline
Old 08-08-2006, 08:19 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
lamao!!! If u have an internet enabled pc infront of u then y in the hell wud u use ur 2inch mobile screen for surfing!!!
anyways nice tip pathiks...
My Rig: AMD Phenom II 550BE | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 08-08-2006, 08:31 PM   #4 (permalink)
Google Bot
Pathik's Avatar
@prankie he mite want to connect to ngage arena....
Pathik is offline
Old 08-08-2006, 08:39 PM   #5 (permalink)
Stay Silent!
enticer86's Avatar
no the thing is tht PC is used by my sis n dad too, n i need internet a lot of time...so to prevent time class i can use it on my cell...wotsay
n whts softs do i need?
Old 08-08-2006, 09:08 PM   #6 (permalink)
18 Till I Die............
As pathiks said, you need Gnubox.
http://gnubox.dnsalias.org/gnubox/sharing.html
http://www.bash.org/?258908
mehulved is offline
Old 09-08-2006, 12:46 PM   #7 (permalink)
Google Bot
Pathik's Avatar
and pls dont ask how to connect.... jus google it and u ll get lotsa links......
Pathik is offline
Old 10-08-2006, 12:39 PM   #8 (permalink)
Stay Silent!
enticer86's Avatar
Angry Re: using PC Internet on cell
Guys my prob is tht under the networks tab, BT PAN NETWORK CARD IS NOT PLUGGED...
HELP ME PLS
Old 10-08-2006, 12:42 PM   #9 (permalink)
Google Bot
Pathik's Avatar
reinstall bt drivers and make a full install...
Pathik is offline
Old 10-08-2006, 12:53 PM   #10 (permalink)
Stay Silent!
enticer86's Avatar
tried tht,....still it doest work...wht cud b the prob?
Old 10-08-2006, 12:57 PM   #11 (permalink)
Google Bot
Pathik's Avatar
wich cell do u hav.... maybe it doesnt support that service...
Pathik is offline
Old 10-08-2006, 12:59 PM   #12 (permalink)
Stay Silent!
enticer86's Avatar
nokia 7610
i hope it supports tht
Old 10-08-2006, 01:02 PM   #13 (permalink)
Google Bot
Pathik's Avatar
yup of course it supports that... lemme try that...
Pathik is offline
Old 10-08-2006, 01:18 PM   #14 (permalink)
Stay Silent!
enticer86's Avatar
thnx in advance yaar...its sooo embarrassing a person who mastered installin windows n stuf in class 6 is now so helpless(
on the computer the trouble is tht i only get the error: BT PAN NETWORK: A NETWORK CABLE IS UNPLUGGED...Whch cable is it talkin abt???
i gt another DOUBT! i hav installed GNUBox on my cell n startin it says "no BT isp..." tht means if i get Bt to show in my connection settings in cell, it can automatically work...whtsay?
Old 10-08-2006, 01:50 PM   #15 (permalink)
Well there's no cable here. It is referring to a bluetooth connection. If you have a device connected to your PC overbluetooth, the PAN adapter will show as connected. The error you get means that no device is connected via bluetooth at the present.
mehulved is offline
Old 10-08-2006, 02:01 PM   #16 (permalink)
Stay Silent!
enticer86's Avatar
i made it sho Connected now!!!! but the step 1 fr GNU Box disables internet on the pc!
Old 10-08-2006, 02:43 PM   #17 (permalink)
Google Bot
Pathik's Avatar
see get gnubox for ur cell here
http://gnubox.dnsalias.org/gnubox/gnubox_7610.sis
and check out these links....
http://www.cs.helsinki.fi/u/mraento/symbian/bt-ap.html
http://www.symbianos.org/cgi-bin/viewcvs.cgi/gnubox/
Pathik is offline
Old 12-08-2006, 12:27 PM   #18 (permalink)
Stay Silent!
enticer86's Avatar
thnx its really helpful...tho now my cell gets connected, i cant surf the web...the error i get is:
WEB: NO GATEWAY REPLY
Old 12-08-2006, 02:24 PM   #19 (permalink)
Google Bot
Pathik's Avatar
do u hav a broadband conn.
Pathik is offline
Old 12-08-2006, 06:20 PM   #20 (permalink)
Stay Silent!
enticer86's Avatar
i am using Airtel ADSL thing...nt exactly broadband....i kno pretty well its abt DNS settings or snthing...rite?
i m using airtel ADSL thingy
n now the error is
GENERAL: ALREADY IN USE
isnt there any simple way?
