Old 07-08-2006, 11:57 AM   #1 (permalink)
Mobile Freak
reddick's Avatar
Question Which is the best : Dial-up OR Mobile Office?
My PC runs on WinXP Pro.I surf via dial-up conn. of SATYAM.But now whenever i try to connect,i gt this error message - "Error : 678.The remote computer did not respond." I call CustomerCare but they also r helpless Somebody please tell me how to solve this? Secondly,i'm planning to have AIRTEL MOBILE-OFFICE to surf web on PC.Here they charge 375K monthly for unlimited access.Is it a gud option I have N70 phone connected via data-cable.I heared that connecting it via bluetooth gives more surfing speed!Is it true? Please ans. all my querries...THANKS FOR YOUR REPLIES!!!
Hope 4 d best n Do d right :)
reddick is offline
Old 07-08-2006, 12:21 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Which is the best : Dial-up OR Mobile Office?
MO rox....
on ur fone it ll give a dload speed of 20 kbps and a connection speed of 300+ kbps
Pathik is offline
Old 07-08-2006, 01:44 PM   #3 (permalink)
rahul_becks23's Avatar
ok........i also have this MO conn. thing but it does not work on my com.........what do i have to do in order to make it work.......i live in chandigarh.
rahul_becks23 is offline
Old 07-08-2006, 03:20 PM   #4 (permalink)
din
Tribal Boy
din's Avatar
I am using MO form Airtel for the last 12 months. It is not the best option but not very bad too. We will get 30-40 kbps max. Regarding connection, first you need to get it activated from Airtel. U can use any method, I mean bluetooth, cable, IR etc. For data transfer cable will be better but as the internet speed is not that much, it won't make any difference. My scheme was advance rental, that is Rs.125 per month (have to pay 12 months rental in advance). Just chk whether that scheme is still there.
din is offline
Old 07-08-2006, 05:58 PM   #5 (permalink)
Mobile Freak
reddick's Avatar
Please ans. this:
And this too:
Majority of ppl recommend MO good!!!
reddick is offline
Old 07-08-2006, 06:02 PM   #6 (permalink)
!FREEWARES!
Akshay's Avatar
MO provides u mobility. Speed these days is gud for MO but the rental has gone up to Rs.350p.m. So instead if mobility is not an issue, go 4 broadband
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 07-08-2006, 06:18 PM   #7 (permalink)
Venom's Avatar
Get a broadband connection better.
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 07-08-2006, 07:49 PM   #8 (permalink)
prasad_den's Avatar
Yup... If you are gonna spend ~400 bucks for MO, you can get BSNL BB for 500 p/m.. That would be a better idea..!!
prasad_den is offline
Old 07-08-2006, 09:40 PM   #9 (permalink)
i have activated it on my W550i.......now what to do......
Old 08-08-2006, 12:33 PM   #10 (permalink)
Mobile Freak
reddick's Avatar
i don't wana broadband.i'd settle on MO...it's better optiom i think!
reddick is offline
Old 08-08-2006, 12:35 PM   #11 (permalink)
The Devil's Advocate
iMav's Avatar
it depends on what ur requirement is .... y dont u try reliance or tata's data cards ....
http://beingmanan.com
iMav is offline
Old 08-08-2006, 01:14 PM   #12 (permalink)
can anyone help me regarding using MO on my PC
Old 08-08-2006, 01:36 PM   #13 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Which is the best : Dial-up OR Mobile Office?
Originally Posted by reddick
My PC runs on WinXP Pro.I surf via dial-up conn. of SATYAM.But now whenever i try to conne00 ct,i gt this error message - "Error : 678.The remote computer did not respond.
the same error occurs to me
this error occurs when their is some power failure in the line.....
satyamy is offline
Old 08-08-2006, 02:01 PM   #14 (permalink)
Venom's Avatar
Your opinion ofcourse.
@rahul~ - start a new thread for your query, dont tend to hijack please :]
Venom is offline
Old 08-08-2006, 02:05 PM   #15 (permalink)
ok,ok..........cool on buddy
Old 09-08-2006, 01:35 AM   #16 (permalink)
vysakh's Avatar
MO would be better option as the N70 supports EDGE. you'll get download speeds of 20-25 kBps
Incompatible message format
vysakh is offline
Old 09-08-2006, 01:56 AM   #17 (permalink)
Ishan's Avatar
Please ans. this:
And this too:
no data cable will be faster than bluetooth..i read somewhere in this forum only.
I'll post the link if i'll get it.
ok got this read it..
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 10-08-2006, 07:54 AM   #18 (permalink)
Mobile Freak
reddick's Avatar
I have 50 hrs. left on SATYAM.So i'll gona have to spend them b4 switching to MO.
reddick is offline
Old 10-08-2006, 09:05 AM   #19 (permalink)
just sms for mo setting for your w550. when you receive the setting, just install it. make a internet connection in your pc using w550. for further assistance just call customer care mo.
sanju is offline
Old 10-08-2006, 12:15 PM   #20 (permalink)
Google Bot
Pathik's Avatar
of course data cable speeds r higher than BT....
BT l give u a conn speed of 115.2 kbps and cable ll give u a conn speed of 340.xx kbps......
Pathik is offline
Old 20-08-2006, 06:11 PM   #21 (permalink)
Mobile Freak
reddick's Avatar
Well their is no power failure here.
I contact SATYAM customercare today.They told me that ur modem drivers must be re-installed.I did that but i gt same error again,"Error - 678.The remote computer did not respond."
Sometimes it get connected fine but mostly it fails Please help me on this...I'm losing my 50 hrs. as my validity will soon expire
THANKS FOR UR REPLIES!!!
reddick is offline
Old 21-08-2006, 06:46 PM   #22 (permalink)
Mobile Freak
reddick's Avatar
AnyOne Plz HELP...Still waiting for ur replies
reddick is offline
