Old 02-08-2006, 07:33 PM   #1 (permalink)
Default How to Convert Mp3 to WAV
Hi,
Am having Nokia 3230, is there any software to convert mp3songs to wav, so that i can use as ring tone..
Regards
Saran
sarvanan is offline
Old 02-08-2006, 07:59 PM   #2 (permalink)
I see right through you.
Sykora's Avatar
Default Re: How to Convert Mp3 to WAV
Just rename it, there's no real conversion taking place. Wav is a higher fidelity format, so the music isn't going to get any better because there's no extra detail suddenly coming into play because it's a wav.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 02-08-2006, 08:15 PM   #3 (permalink)
shashank4u's Avatar
use super from www.erightsoft.com
support almost all of the formats.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 02-08-2006, 08:27 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
iTunes can also do the Job.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 03-08-2006, 12:31 AM   #5 (permalink)
Neil is Here...
coolendra's Avatar
Welll i wud suggert u try xilisoft audio converter.... all in one package....
goood stuff !!!!!!!
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
Old 03-08-2006, 09:29 AM   #6 (permalink)
thanks folks..........
sarvanan is offline
Old 03-08-2006, 10:23 AM   #7 (permalink)
Google Bot
Pathik's Avatar
use dbpoweramp....
Pathik is offline
Old 06-08-2006, 01:35 AM   #8 (permalink)
csczero's Avatar
Smile Re: How to Convert Mp3 to WAV
use GOLDWAVE its simple small and free with lots of features converts any audio file to any audio format my favourite
csczero is offline
Old 13-08-2006, 12:58 PM   #9 (permalink)
Thumbs up Re: How to Convert Mp3 to WAV
Simple.....
Use Jet Audio....
Spawn - The Gaming Freak :)
Spawn Freak is offline
Old 13-08-2006, 02:15 PM   #10 (permalink)
D PrankMaster
prankie's Avatar
I used to use dBpoweramp. gives u all sorts of options..
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 13-08-2006, 02:28 PM   #11 (permalink)
18 Till I Die............
What's the use of conversion?
It will only increase the size of the file and not quality. Nokia 3230 can use mp3's as ringtone.
http://www.bash.org/?258908
mehulved is offline
Old 13-08-2006, 02:55 PM   #12 (permalink)
D PrankMaster
prankie's Avatar
Mp3 ringtones in older symbian phones like 6670 did'nt sound loud... wav ringtones sound much louder..
prankie is offline
Old 13-08-2006, 03:10 PM   #13 (permalink)
Google Bot
Pathik's Avatar
yeh the sound volume is good in wav tones...
Pathik is offline
Old 13-08-2006, 03:16 PM   #14 (permalink)
That only holds true for a wav tone if it has original quality. Once converted to an mp3, it looses it's quality. There was a discussion on this in the forum. So, once you convert it into mp3 then back to wav, it won't be of nay use. One of you'll can try it and post back the results.
mehulved is offline
Old 13-08-2006, 05:44 PM   #15 (permalink)
Google Bot
Pathik's Avatar
thats applicable in PCs... in cells generally a mp3 has a low volume compared to wav tones....
Pathik is offline
Old 14-08-2006, 01:43 AM   #16 (permalink)
Tech.Masti's Avatar
convert mp3's to AMR, it take less space, and sound will be not so bad.
Tech.Masti is offline
