Old 31-07-2006, 12:36 PM   #1 (permalink)
Unhappy Need Help
My nokia 6630 is showing as offline mode. unable to call or receive calls as it shows as offline mode in the operator logo's place.if i select general mode manually it is displaying as "insert sim".while all other sims are working fine with my mobile and my sim is working fine with others mobiles. so any body help me to solve the problem.
jrsc is offline
Old 31-07-2006, 12:48 PM   #2 (permalink)
tuxfan's Avatar
Default Re: Need Help
I think you will have to change your SIM. Contact your operator and get it changed. Is it very old? Was it mis-handled?
tuxfan is offline
Old 31-07-2006, 03:33 PM   #3 (permalink)
Google Bot
Pathik's Avatar
have u installed psiloc system tools.....
format ur fone...
Pathik is offline
