Old 29-07-2006, 06:16 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default How to uninstall softwares in Nokia 6630???
Hello friends!
I just brought a Nokia 6630 and have a few doubts related to the same...
1. I installed a few softwares in my mobile and now I want to uninstall a few of them as they are of no use. I tried to uninstall them through Application Manager, but they are not listed there. Kindly let me know how can I uninstall those softwares.
2. Where can I get the latest firmware for my mobile?
3. Is it possible to bring the mobile to the same stage as when it was brought. Doing so should automatically uninstall all installed softwares and make my mobile absolutely clean.
4. Where can I get a guide to Symbian 60?
5. How can I set a wallpaper in fullscreen mode. Actually whenever I am trying to set my personal wallpaper, it doent get fullscreen. The upper and the lower end still remains of the current theme selected.
Kindly help.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 29-07-2006, 08:00 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: How to uninstall softwares in Nokia 6630???
for uninstalling delete the folder of the app 4m e/system/apps or c/system/apps......
another way is install the app again(overwrite)....then uninstall 4m app manager...
u ll find the firmware on the net....
Pathik is offline
Old 29-07-2006, 10:46 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
Yup!! use free software like fexplorer for doin that...
regarding wallpaper.. check whether the image's reso is 176*144... if its greater or less than that then it wont fit on fullscreen.....
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 30-07-2006, 01:44 PM   #4 (permalink)
is it possible to upgrade the Firmware at home or do i need to take it to Noika service center?
ashnik is offline
Old 30-07-2006, 01:54 PM   #5 (permalink)
D PrankMaster
prankie's Avatar
can be done at home using a special device.... bettr do it at nokia priority center...
prankie is offline
Old 30-07-2006, 04:55 PM   #6 (permalink)
9437077259
go4saket's Avatar
how can this be done at home...
Win 7 Ultimate
go4saket is offline
Old 30-07-2006, 05:50 PM   #7 (permalink)
Google Bot
Pathik's Avatar
it can be done @ home using a datacable....
but its risky and u r fone may go dead if u make a mistake....
Pathik is offline
Old 30-07-2006, 08:19 PM   #8 (permalink)
D PrankMaster
prankie's Avatar
http://www.polarbox2.org/
thats the device i was talkin about...
prankie is offline
Old 31-07-2006, 11:03 AM   #9 (permalink)
Google Bot
Pathik's Avatar
@prankie... thats not needed...
u can flash all bb5 fones @ home... using a datacable
Pathik is offline
Old 31-07-2006, 12:46 PM   #10 (permalink)
shivam's Avatar
u can get ur phoane as a new one just format ur memory card by going to organiser and then memory card and then to format memory card and abt the phone memory just press *#7370# and this will format ur phone.i also have n6630 if u need any help just pm me on makewaysforshivam@yahoo.com.
shivam is offline
Old 31-07-2006, 03:27 PM   #11 (permalink)
Google Bot
Pathik's Avatar
thats jus a reset shivam...
for full formating use the 3 key format..
Pathik is offline
Old 31-07-2006, 10:28 PM   #12 (permalink)
9437077259
go4saket's Avatar
Whats the 3 Key format...
Win 7 Ultimate
go4saket is offline
Old 01-08-2006, 10:32 PM   #13 (permalink)
Google Bot
Pathik's Avatar
switch off
press 3,* and green key....
keep em pressed...
and restart...
Pathik is offline
Old 07-08-2006, 03:02 PM   #14 (permalink)
shivam's Avatar
Lightbulb Re: How to uninstall softwares in Nokia 6630???
switch off
keep em pressed...
and restart...
Thats not works in n6630 thats works in n6600.i am using n6630 and its dosnt works.
shivam is offline
