Old 27-07-2006, 06:32 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
pop143's Avatar
Smile Reset the nokia N70
hi huts..seems some prob with my nokia n70....need 2 rest my phone ..it shud be the same..of wot i got @ new it was....where to download nokia n70 phone sofware? how to reset it to new..anybody know..??
pop143 is offline
Old 27-07-2006, 10:43 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Reset the nokia N70
u want to reset it or flash it...
for resetting u dont need ny software...
type *#7370# or *#7780
or the 3 key format
Pathik is offline
Old 27-07-2006, 01:05 PM   #3 (permalink)
pop143's Avatar
or the 3 key format
hi..if i reset it...will all the software they installed on the phone...will be available again..will it be there?? or complete erase..???
pop143 is offline
Old 27-07-2006, 02:22 PM   #4 (permalink)
Google Bot
Pathik's Avatar
the default softs ll be installed but the 3rd party ones u installed ll be removed
Pathik is offline
Old 27-07-2006, 04:15 PM   #5 (permalink)
mobilegeek's Avatar
For reset --> *#7370#, ....
*#7780# just restores the default settings
mobilegeek is offline
Old 27-07-2006, 04:20 PM   #6 (permalink)
Google Bot
Pathik's Avatar
even *#7370# doesnt delete the entire data...
the best is the 3 key format
Pathik is offline
Old 27-07-2006, 07:04 PM   #7 (permalink)
hi,
wanna n70 softwares in a single place?
here's the torrent link
http://www.mininova.org/search/?search=n70
I don't know torrent links are legal or not in this forum,
if it illegal pls ignore the link.
Raaza is offline
Old 27-07-2006, 11:45 PM   #8 (permalink)
pop143's Avatar
wot is 3 key format..?
pop143 is offline
Old 28-07-2006, 11:34 AM   #9 (permalink)
Google Bot
Pathik's Avatar
switch off ur fone... press the '3' '*' 'green' key and restart keepin them pressed...
Pathik is offline
Old 28-07-2006, 11:50 AM   #10 (permalink)
D PrankMaster
prankie's Avatar
hmm..... does the 3 key format works on all symbi phones???
i mean even in the newer symbi phones!!! have u tried it???
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 28-07-2006, 12:13 PM   #11 (permalink)
Google Bot
Pathik's Avatar
yup it works on all except os6.1 fones.....
Pathik is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/32770-reset-nokia-n70.html
Reset nokia N70 Mobile Monsters Question This thread Refback 21-08-2010 05:18 PM
