Old 25-07-2006, 08:28 AM   #1 (permalink)
Crazy Kidd's Avatar
Wink Surfing net using Airtel Live.
You need a PC or a Laptop and the required connectivity tools, i.e. Serial/USB cable OR Infrared Device OR Bluetooth dongle
1) Activate Airtel Live! ( It's FREE so no probs).
2) Create TWO Airtel gprs data accounts (yes TWO) and select the FIRST as the active profile.
3) Connect your mobile to the PC (or Laptop) and install the driver for your mobile's modem.
4) Create a new dial-up connection using the NEW CONNECTION WIZARD as follows :
Connecting Device : Your mobile's modem
ISP Name : Airtel (or anything you like)
Phone Number : *99***2#
Username and Password : blank
5) Configure your browser and download manager to use the proxy 100.1.200.99 and port 8080.( My advice is to use Opera since you can browse both wap and regular websites)
6) Connect to the dial-up account. You will be connected at 115.2 kbps (but remember, that is a bad joke).
7) Pick up your mobile and try to access any site. You will get "Access Denied..."(except for Airtel Live!). IT DOES NOT MATTER. Keep the mobile down.
8 ) On the PC ( or Laptop) open your browser, enter any address, press ENTER and.......WAIT
9) After a few seconds the page will start to load and you have the WHOLE internet at your disposal.
The Settings on Sony Ericcson K700i Mobile
Under DATA COMM
APN : airtelfun.com
USERNAME : blank
PASSWORD : blank
PASS REQ : OFF
ALLOW CALLS : AUTOMATIC
IPADDRESS :
DNSADDRESS :
DATA COMP : OFF
HEADER COMP : OFF
Under INTERNET PROFILES
INTERNET MODE : HTTP or WAP (both worked for me)
USE PROXY : YES
IP ADDRESS : 100.1.200.99
PORT : 8080
USERNAME :
PASSWORD :
Source... sigh!
Crazy Kidd is offline
Old 25-07-2006, 10:37 AM   #2 (permalink)
Default Re: Surfing net using Airtel Live.
in my mob i can see only airtel live, but really! can i see all the pages when I connect airtel live to the pc?
abhis_8086 is offline
Old 25-07-2006, 10:55 AM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
This is 3rd thread with same topic. Refer to threads by afterlife... The contents and procedure is the same except for the phone no.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is online now
Old 25-07-2006, 12:07 PM   #4 (permalink)
again the same
sanju is offline
Old 25-07-2006, 01:16 PM   #5 (permalink)
Dipen01's Avatar
why 115.2..and not more...???
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
Old 25-07-2006, 04:56 PM   #6 (permalink)
!FREEWARES!
Akshay's Avatar
@dipen01
coz dats what airtel can provide at the moment 115.2kbps... not more than that...
MBP 13.3";
Old 25-07-2006, 09:42 PM   #7 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
hey that's fine....but i don't think the airtel peopl r such fools...i recommend u to check ur month's itemised bill and detailed billing after such use....
panacea_amc is offline
Old 25-07-2006, 11:11 PM   #8 (permalink)
i tried it ,its nice it getz connected but! it disconnected in the next 2 minutes what will be the reason ? is there any more settings to remove the timer to disconnect the connection.
steelwin is offline
Old 26-07-2006, 02:52 PM   #9 (permalink)
!FREEWARES!
Akshay's Avatar
@panacea
I had called up airtel to confirm d same n dey wer adamant dat such thing can nevr happn... so b**** to them
@steelwin
I dont get discnnctd unless I myself discnnt. Chk if u r receiving calls/sms at dat time. It gets discnnctd for dat much duration
MBP 13.3";
Old 26-07-2006, 03:02 PM   #10 (permalink)
what are the settings for nokia 6600
"The time you enjoy wasting is not wasted time."
abhishek_734 is offline
Old 26-07-2006, 03:21 PM   #11 (permalink)
Google Bot
Pathik's Avatar
@dipen 115.2 is the max BT conn speed..
and this is a year old trick...
Pathik is offline
Old 26-07-2006, 09:30 PM   #12 (permalink)
Dipen01's Avatar
so at preset none of service providers provide more than that..???
Dipen01 is offline
Old 27-07-2006, 11:25 AM   #13 (permalink)
!FREEWARES!
Akshay's Avatar
@dipen
EDGE will be faster than that...
@abhishek
Refer to threads at mobile monsters
MBP 13.3";
Old 27-07-2006, 11:41 AM   #14 (permalink)
Google Bot
Pathik's Avatar
@dipen,akshay.... if u connect using BT u cant get more than 115.2 kbps cos its the max BT conn speed... whether u r using edge or 3g....
if u use a datacable then u ll get more speeds than that...
and 115.2 kbps is also a great speed..
Pathik is offline
Old 27-07-2006, 10:58 PM   #15 (permalink)
Dipen01's Avatar
Ill prefer data cable den...but...damn mine is USB 1.0...am scrwed either ways...
anyways..i know it wont affect much..
Dipen01 is offline
Old 28-07-2006, 12:51 PM   #16 (permalink)
Google Bot
Pathik's Avatar
yup it wont affect much... cos usb transfer speeds r neday more than net speeds...
Pathik is offline
Old 28-07-2006, 02:20 PM   #17 (permalink)
Check out the latest posts in this thread on how to tweak your airtel live settings for better speed:
http://www.esato.com/board/viewtopic.php?topic=111345
blu_6779 is offline
Old 15-08-2006, 05:09 PM   #18 (permalink)
Dipen01's Avatar
btw...what would be process for using NEt thru W810i on PC...i hav already activated GPRS.. how do i configure...??
Dipen01 is offline
Old 15-08-2006, 06:33 PM   #19 (permalink)
Google Bot
Pathik's Avatar
so u tuk it.... jus act ur MO... switch on BT... create a new BT DUN conn selecting ur BT DUN MODEM and connect..... no- *99#
Pathik is offline
Old 16-08-2006, 04:08 PM   #20 (permalink)
Is it faster than normal Dialup Connections.
sushantvirdi is offline
Old 16-08-2006, 05:59 PM   #21 (permalink)
Google Bot
Pathik's Avatar
in general its faster... but depends on gprs ntwk/speed in ur area... on ur fone, type of conn etc...
Pathik is offline
Old 19-08-2006, 05:13 PM   #22 (permalink)
Under DATA COMM
APN : airtelfun.com
USERNAME : blank
PASSWORD : blank
PASS REQ : OFF
IPADDRESS :
DNSADDRESS :
DATA COMP : OFF
HEADER COMP : OFF
USE PROXY : YES
PORT : 8080
USERNAME :
PASSWORD :
I tried all the above procedure, but my connection is terminated when Registering my computer on the internet.....what's the probe...????i tried all other altenatives like reinstalling bluetooth drivers, updated them, changed airtel live settings as default in my nokia 66oo, reinstalled bluesolleil 1.6,
i guess in the modem properties of Control pannel-> Phone & modems->Bluetooth DUN Connection->properties->in the advance menu-> Extra initialiazation commands we need to write the code for airtel mobile office.
plz help....
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 20-08-2006, 12:17 AM   #23 (permalink)
Ishan's Avatar
I think when anything is stopped downloading or finished downloading....then it might be getting disconnected.!
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 21-08-2006, 12:46 AM   #24 (permalink)
Core of the Processor
can this work with SE K300i
jmit is offline
Old 21-08-2006, 02:54 PM   #25 (permalink)
official's Avatar
Location: A small town near Siliguri, West Bengal in Darjeeling district
Is it not Illegeal.If they Know Whatt can they do because airtellive if free service not meant for using net on computer.I have both mobile office and airtel live activated.As the mobile office rental has decreased i want to deactivate it and start with airtel live.Wont it be a crime.
official is offline
Old 25-08-2006, 01:35 PM   #26 (permalink)
Crazy Kidd's Avatar
It is faster than normal dial up. But if you can spend 99 per month and activte Airtel wap then you can surf more easily.
Old 26-08-2006, 01:09 PM   #27 (permalink)
how do i activate airtel live.
mehta708 is offline
Old 26-08-2006, 04:08 PM   #28 (permalink)
Google Bot
Pathik's Avatar
call cc n tell em to do it..
Pathik is offline
Old 28-08-2006, 08:39 PM   #29 (permalink)
The Devil's Advocate
iMav's Avatar
guys i am not able to connect ..... irt says dialing the number and then says conx attempt failed modem on remote device not working
i dont know whats the problem i have paired my fone with my pc i am ufrak and also transferring files without any hassles .... i hav billionton class 1 bt dongle
http://beingmanan.com
iMav is offline
Old 29-08-2006, 09:34 AM   #30 (permalink)
official's Avatar
Use Extara initialization command on modem properties. AT+CGDCONT=,,"airtelfun.com"<cr>
__________
But I am Saying u that it is illegal.Airtel can Claim on u
official is offline
