Old 22-07-2006, 01:01 PM   #1 (permalink)
Default Urgent : 3230
Hi Friends.... I have 3230, I have not activated MMS, but recently atomically my phone hangs for every 7-10 minutes...when it returns. it reads that a MMS message is in outbox... what could be a problem,
I am from Bangalore.....have 512 mb card and not much files are stored....
Kindly advice me on this and also let me know whether can i go for any upgradition is required....
sarvanan is offline
Old 22-07-2006, 01:51 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Urgent : 3230
scan with a antivirus....also try rebooting without Mmc
or format ur cell.....
Pathik is offline
Old 22-07-2006, 02:22 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
comwarrior has got in ur mobile phone... scan ur mobile phone with antivirus.
if it does'nt help than format ur phone....
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 22-07-2006, 02:55 PM   #4 (permalink)
The Devil's Advocate
iMav's Avatar
no use scanning .... format it
http://beingmanan.com
iMav is offline
Old 22-07-2006, 03:04 PM   #5 (permalink)
Google Bot
Pathik's Avatar
nope netquin /norton can remove commwarrior easily....
and if u do format then use the 3key one
Pathik is offline
Old 22-07-2006, 03:53 PM   #6 (permalink)
Thanks .... but how to scan...should i instll a scan software... or reformating the phone ?? how can you pls tell me..card is not a problem ...as i recently purchased and copied all my datas from my old card (old card reformatted before itself)
can you name me the URL for anti virus software...
sarvanan is offline
Old 22-07-2006, 03:56 PM   #7 (permalink)
Google Bot
Pathik's Avatar
google it... and best of all format the cell...
Pathik is offline
Old 22-07-2006, 04:21 PM   #8 (permalink)
folks...thanks i got the software..installed ..found 4 virus and deleted it...also have one more problem..when i send text message...it takes 2 minutes to send..i.e. the moment i press send..it says sending message..after 2 minutes only ..it says send... can you please tell me .....
sarvanan is offline
Old 22-07-2006, 04:49 PM   #9 (permalink)
Google Bot
Pathik's Avatar
thats not a phone prob.... maybe a network problem...
Pathik is offline
Old 24-07-2006, 08:58 AM   #10 (permalink)
no even i tried with other network using my friends sim...but still the same problem....
sarvanan is offline
