Old 22-07-2006, 10:01 AM   #1 (permalink)
Default Need MMC !!!
I have a Nokia 6600 and I have only a 32mb MMC card. I wanna go for a good 512mb or a 1gb card, but I don't know if the phone'll support it. Can someone please tell me how much memory it'll support, and what a 512mb and a 1gb card will set me back by ?
Thanks
esh1manarsenal is offline
Old 22-07-2006, 11:51 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Need MMC !!!
1GB yaar.... get a RSDV 1GB NCP mmc for 1200/-
my guarantee it ll work
Pathik is offline
Old 22-07-2006, 04:55 PM   #3 (permalink)
You sure ? I asked at Nokia Priority and they told me a 512 costs 1000. If a 1gb costs 1200 and my phone does support it, then hell - I'd rather go for it. Cool, I'll ask around.
Old 22-07-2006, 10:28 PM   #4 (permalink)
prasad_den's Avatar
512MB would be a better option if you would like your phone to work at the same speed.. A 1GB card slows it down, and sometimes makes it hang..
prasad_den is offline
Old 22-07-2006, 10:32 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
1 gb card does not slow anythig until and unless u go bonkers and start filling the entire 1 gb .... other than that 1 gb cards wrk fine on 6600 i second pathiks' guarantee
http://beingmanan.com
iMav is offline
Old 22-07-2006, 11:22 PM   #6 (permalink)
tosh_mine's Avatar
for 6600 256 is the best.
512 but will slow down ur phone a bit.
512+ dont go for them
BTW 512MB NCP MMC is for Rs.500/-
tosh_mine is offline
Old 22-07-2006, 11:31 PM   #7 (permalink)
Google Bot
Pathik's Avatar
i m using a 1GB on my ngage Qd and its faster than ever.....
so i suppose u shd take it...
Pathik is offline
Old 23-07-2006, 07:38 AM   #8 (permalink)
maharajadhiraj's Avatar
The Nokia dealer from whom i bought my 6630 said that it wud b better if we use 512 MB card on phones like 7610,6600,6630,6670. He said that we use 1gb card, it will "hang a lot". Hence I got a 512 Mb MMC card for 1100/- bucks.........
maharajadhiraj is offline
Old 23-07-2006, 11:12 AM   #9 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Dont buy NCP - Samsung - MicroSim
Just Buy Kingston or Transcend Always
DV-RS MMC 512MB - Rs 800
5 Yr warranty
rollcage is offline
Old 23-07-2006, 12:17 PM   #10 (permalink)
Originally Posted by anarchist
523MB???????
oooops, that was a typing mistake
Old 23-07-2006, 06:00 PM   #11 (permalink)
Transcend is not available every where..btw here in hyd i have only seen ncp mmc cards and yes they are selling...infact even i got a 1Gb for 1200
For 6600 i suggest you go for 2*512 Mb mmc cards..its gonna cost you the same
cyrux is offline
Old 23-07-2006, 06:06 PM   #12 (permalink)
prasad_den's Avatar
If you are not gonna fill the 1 GB then why do you need it at all..???
