Old 20-07-2006, 08:34 PM   #1 (permalink)
Default memory card for nokia 3230
i purchased nokia 3230 ,5 months back at that time i got only 32 mb RS MMC which is not sufficient for me, pls tell me what is the maximum size( i mean MB) of memory card which this phone can support?? and also its price and brand?
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 20-07-2006, 08:52 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: memory card for nokia 3230
1gb Ncp 1400/-
Pathik is offline
Old 21-07-2006, 12:03 AM   #3 (permalink)
1 Gb Ncp is for 1200 here in hyderabad , but i suggest you go for a 512Mb card since the processor of 3230 cant handle 1Gb with great pace
cyrux is offline
Old 21-07-2006, 09:47 AM   #4 (permalink)
is it really slow??? , i mean .. i dont mind if it is little slow, all i want is more space
pls tell me if possible, how many seconds approximately it will take to move from one folder to another or opening one mp3 or video file or aaplications file??
thnx cyrux and pathiks for quick reply..
i also wanna ask one question:
i have read at may places that nokia 3230 dont support more than 256 MB or 512 MB memory card ,, is it true??
paul_007 is offline
Old 21-07-2006, 09:53 AM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
even i am thinking of going in for a i gb card for my 6600 my friend is using the combo and he says that because he filled the entire 1 gb his fone lags a little .... else everything is fine
http://beingmanan.com
iMav is offline
Old 21-07-2006, 10:13 AM   #6 (permalink)
_______'s Avatar
go for a 512Mb card
_______ is offline
Old 21-07-2006, 10:16 AM   #7 (permalink)
18 Till I Die............
If you want 1GB, rather carry 2 DV-RS MMC cards of 512MB. I am having a 512MB MMC card in my Nokia 3230 and it's made the phone real slow. And, since the card is hot swappable, you can swap b/w the cards anytime yuo like.
http://www.bash.org/?258908
mehulved is offline
Old 21-07-2006, 11:12 AM   #8 (permalink)
Google Bot
Pathik's Avatar
i m using a 1gb rs dv mmc in my qd with 70 mb empty... and no probs... u should take a 1 gb only...
Pathik is offline
Old 21-07-2006, 01:43 PM   #9 (permalink)
i dont want to carry two separate cards because i will then have to open the cellphone panel again and again which will loosen the back panel of phone in the future, so i think 1 GB will be better
since pathik is using 1 GB card in his engage qd without any problem i dont think it will creae any problem in nokia3230,
paul_007 is offline
Old 21-07-2006, 03:45 PM   #10 (permalink)
iMav's Avatar
i am also banking on what my friend is saying but only time will tell whether 1gb cards make the fones slow or no
iMav is offline
Old 21-07-2006, 09:44 PM   #11 (permalink)
t3h g04t
teknoPhobia's Avatar
It will bcome slow if you have a lot of content that's cuz s60 phones scan your entire memory card to find and sort content and appz.
technologically challenged.
teknoPhobia is offline
Old 21-07-2006, 10:04 PM   #12 (permalink)
Google Bot
Pathik's Avatar
and always keep ur c/ clean ...
then u should not face ny probs.... also dont install ny antiviruses..
Pathik is offline
Old 22-07-2006, 11:29 PM   #13 (permalink)
tosh_mine's Avatar
Go for 512MB card. ncp=rs.500/- in mumbai
tosh_mine is offline
Old 24-07-2006, 06:31 PM   #14 (permalink)
hi teknoPhobia u rite , with one GB card my phone is lagging more than wat i expected( even it is 200 MB filled), it takes more than 40 to 50 seconds to move frm one folder to another, and takes 40 seconds to enter into memory card directory i will now replace it with two 512 MB cards..
paul_007 is offline
Old 24-07-2006, 07:35 PM   #15 (permalink)
You are the first person who is asking to prevent an antivirus... why do you say that ??
cyrux is offline
Old 24-07-2006, 08:21 PM   #16 (permalink)
Simply because it takes up resources while running in the background. So, it makes your phone slower.
mehulved is offline
Old 24-07-2006, 09:22 PM   #17 (permalink)
Google Bot
Pathik's Avatar
yup dont use antiviruses....
be ur own antivirus.... dont accept files 4m unknown people...
and delete the suspicous system files if u think u r infected
Pathik is offline
Old 24-07-2006, 09:43 PM   #18 (permalink)
where bro? and ne warranty?
ashnik is offline
Old 24-07-2006, 09:55 PM   #19 (permalink)
So i guess the best thing to do is not to use an antivirus installed on your phone. Just keep an installer file and install it once a week to scan your phone...what say ??
cyrux is offline
