Old 18-07-2006, 11:53 AM   #1 (permalink)
D PrankMaster
prankie's Avatar
Exclamation Cleaning mob. screen???
I have N3250, after using crystal cover for abt a month, i realised that it was a waste of money.. coz when i removed it i saw many scratches and stains on both the sides of the fone... the reason may be because of the design of the case, dust gets in and keep scratching the mob's surface... so my question is that, can scratches be removed from the mobile's screen???
if yes, than how???
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 18-07-2006, 12:40 PM   #2 (permalink)
Default Re: Cleaning mob. screen???
nothing can be doun
either u can change the body
or attach a scratch gard original that can cover your scratches
maheshmax is offline
Old 18-07-2006, 02:17 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Simply buy a new faceplate for ur mobile...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 18-07-2006, 04:31 PM   #4 (permalink)
D PrankMaster
prankie's Avatar
Will thinner help???
prankie is offline
Old 18-07-2006, 05:01 PM   #5 (permalink)
prasad_den's Avatar
thinner...to remove scratches..?? I don't think so. But if you really wanna give a try before opting for a new screen cover, go to any of those small watch repair shops. They have rotating buffs, which can remove minor scratches when used with some fine abrasives. Worth giving a try..!!!
prasad_den is offline
