Old 02-07-2006, 08:53 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default best audio format for playing music on mobile
hey guys i have a nokia 7610,can u tell me the best format(mp3,aac???)for playing music in it.
sidcool is offline
Old 02-07-2006, 09:06 PM   #2 (permalink)
go_gamez's Avatar
Default Re: best audio format for playing music on mobile
i too have a nokia 6270 ...i only use mp3..but what is the suitable bitrate to get best sound quality,good volume as well as small files..like 1 or 2 mb each (instead of 4-5 mb )
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 03-07-2006, 12:06 AM   #3 (permalink)
go_gamez's Avatar
ok but i got only 128 mb card complimentary ..the 1 gb or 512 mb mini sd is quiet expensive..so it will take time for me to buy it ..
512 MB DDR RAM .
go_gamez is offline
Old 03-07-2006, 07:06 PM   #4 (permalink)
t3h g04t
teknoPhobia's Avatar
AAC gives better quality for a lower size
technologically challenged.
teknoPhobia is offline
Old 04-07-2006, 04:47 PM   #5 (permalink)
i have used the realmedia format(rm8) at 56kbps and it gives sound quality as good as 64kbps mp3.
sidcool is offline
Old 05-07-2006, 05:42 PM   #6 (permalink)
Hello to all,
I am new member in this group..... can you please tell some good software where i can compress 5mb (mp3song) to 1mb .... I have Nokia 3230 phone and have 512 mb card.
Thanks
saran
Hello to all,
I am new member in this group..... can you please tell some good software where i can compress 5mb (mp3song) to 1mb .... I have Nokia 3230 phone and have 512 mb card. You can mail me the link to saran_pillai@hotmail.com
Thanks
saran
sarvanan is offline
Old 06-07-2006, 02:49 PM   #7 (permalink)
Re: saran
u can use nero 6 to compress mp3 by lowering the bitrate to 48 or 64kbps(nero burning rom->extras-->encode files) or u can use xilisoft audio encoder www.xilisoft.com
sidcool is offline
Old 06-07-2006, 02:53 PM   #8 (permalink)
go_gamez's Avatar
you can u se mp3 workshop...where u can decrease the bitrate..as well as increase the volume....but 1mb mp3 files sound quality is not that good..atleast if u r a music lover...
512 MB DDR RAM .
go_gamez is offline
Old 06-07-2006, 04:26 PM   #9 (permalink)
Google Bot
Pathik's Avatar
ormat is .OGG for mobiles... but u need OGGPLAY for symbian fones
for converting to OGg use dbpoweramp wit ogg vorbis codec.... search on google and get that
Pathik is offline
Old 06-07-2006, 05:25 PM   #10 (permalink)
deathvirus_me's Avatar
Well ... if u have loads od space , then MP3 for sure (>180 kbps) ... and if ur running short on space then use MP4 ...
deathvirus_me is offline
Old 07-07-2006, 01:06 PM   #11 (permalink)
thanks folks...what is .ra format..where you compress songs from 5 mb to 500KB or less than a mb.... one of my friend sai....any one is aware of this...Kinldy let me know.
sarvanan is offline
Old 07-07-2006, 09:31 PM   #12 (permalink)
Friends can u put some light on what is FLAC.I converted mp3 to .flac,and its size became 32 mb.I had heard that .flac is lossless compresssion,bt how did it compress,infact it increased d size.
Najesh is offline
Old 09-07-2006, 08:24 AM   #13 (permalink)
Stay Silent!
enticer86's Avatar
well i think the same way but being a music lover, cm to think of it, normally u wil listen to around 5-10 songs during a period i mean only a few songs can b ur most favs...so btter keep thm in best quality, since quality is more importnt thn quantity....wotsay guys!
enticer86 is offline
Old 09-07-2006, 11:45 AM   #14 (permalink)
Google Bot
Pathik's Avatar
FLAC is the best quality audio... i think it was invented by Apple...
it is compressed in comparision to WAV
Pathik is offline
Old 09-07-2006, 11:54 AM   #15 (permalink)
martian's Avatar
Smile Re: best audio format for playing music on mobile
I'm using Sony Ericsson. For SE fans, I'd bet on music files ripped as AAC... Damn good Bass! High Profile MP4 ripped at 64+ kbps sounds good too! Dont know about Nokia... I hate Nokia!
Oh my! Such a nice Planet...
But... what am I doing here??
martian is offline
Old 09-07-2006, 01:27 PM   #16 (permalink)
gxsaurav
Posts: n/a
it's a nokia 7610, convert to Real audio format at 64 kbps
Old 12-07-2006, 02:47 AM   #17 (permalink)
use rm files. u can find rm files song free in many sites.
prasad6100 is offline
Old 16-07-2006, 06:40 PM   #18 (permalink)
expertno.1's Avatar
I suggest to get the format in mp3 @ 96 kbps , stereo and at 16000 hz instead of 44000 hz . it will redue ur file size and will be best sound in nokia .
but you must use the software "mp3 player 3.20" for symbian phones .
it gives good and loud sounds.
if u r low on memory , then get the mp3 @ 48 kbps at 32000 hz , mono/stereo ur wish .
it will give u best sound within 2.3 mb .
and the software is "mp3 player 3.20" for symbians .
u can get this software here,
www.mobuniverse.com
Thanks....
Regards....
Expertno.1
expertno.1 is offline
Old 17-07-2006, 11:34 AM   #19 (permalink)
martian's Avatar
Unhappy Re: best audio format for playing music on mobile
MP3s @ 48 kbps?? Dude, you must be nuts! Any MP3s less than 96 kbps are not worth listening!
Rather you can opt for MP4s @ 64 kbps... not bad!
martian is offline
Old 17-07-2006, 11:51 AM   #20 (permalink)
I listed to music using the MP4 format. I encode MP3's to MP4 at 64kbps and honestly, you can't make out the difference. At least not on my SE k750i!
paraman is offline
Old 17-07-2006, 03:15 PM   #21 (permalink)
mAYHEM's Avatar
Use .Ogg @48 kbps(q0 VBR) 16000 Hz,mono.No need to encode stereo bcoz 7610 doesnt support.Try use VBR or ABR bcoz it will give better quality and small size than CBR
Lenovo Y570|eMachines EM350|iPad2 (3G)|iPod (80GB & 160 GB) |Galaxy S2|Galaxy Note|Storm 9500|Nokia 8800|Shure SE535|Sennheiser CX 500.
http://www.speedtest.net/result/445135884.png
mAYHEM is offline
Old 17-07-2006, 10:59 PM   #22 (permalink)
Is M4A better than MP4?i have heard that it gives better compression and quality than MP4 though this format is not supported by all phones
sidcool is offline
Old 18-07-2006, 08:19 AM   #23 (permalink)
mAYHEM's Avatar
Its the same.m4a means an audio mpeg4 file.
mAYHEM is offline
Old 18-07-2006, 11:41 AM   #24 (permalink)
i use ogg....@48 to 64Kbps ....quite satisfied...
who the hack is this??
mukul is offline
Old 18-07-2006, 02:13 PM   #25 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
aac is the BEST audio format for mobiles...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-07-2006, 09:13 PM   #26 (permalink)
this ia bit out of topic,but what is an asf file and how can i play it
sidcool is offline
Old 20-07-2006, 08:22 PM   #27 (permalink)
You should be able to play a asf file in windows media player. I think its a streaming media format.
paraman is offline
Old 20-07-2006, 10:00 PM   #28 (permalink)
Wise Old Crow
blueshift's Avatar
real media format is good for mobiles
http://twitter.com/blueshift155
blueshift is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/31248-best-audio-format-playing-music-mobile.html
Thread what format supported by china mobile? | Digit Forum | BoardReader This thread Refback 11-01-2011 07:30 PM
