Old 02-07-2006, 06:48 PM   #1 (permalink)
Default Sony Ericsson W800i help
Hi guys
My friend has got a w800i model . But he doesnt know how to play videos on it . 3gpo movies are playing fine but formats like avi , mpg , divx are not getting played . Is there any software needed to play them . And btw is it a symbian phone and if so , how can we install any software like fe explorer on it ....
Thanks in advance
madhur
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 02-07-2006, 06:56 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Sony Ericsson W800i help
its .3gp and to run those avi,dat,mpg videos u need extra softwares wich r not available on SE
Pathik is offline
Old 02-07-2006, 11:01 PM   #3 (permalink)
Can u tell me the name of the software which i need and how to install them
mako_123 is offline
Old 04-07-2006, 11:52 AM   #4 (permalink)
D PrankMaster
prankie's Avatar
Sorry buddy!!! Non symbian phones are too dumb....
I mean u wont get any sort of sw for doin that.. because there are'nt any!!!
try convertin the video stuff to *.3gp format..
prankie is offline
Old 04-07-2006, 07:10 PM   #5 (permalink)
prasad_den's Avatar
W800i is a non-symbian phone.. It can play only 3gp videos. So try converting other video formats to .3gp on your PC using softwares like Nokia multimedia converter (available for download free.. google it) and then transfer it to your mobile. Softwares cannot be installed..only java applications can be. You can get java applications at sites like www.getjar.com, but these applications are really pathetic. You can do nothing special using these..
prasad_den is offline
Old 05-07-2006, 12:47 PM   #6 (permalink)
It can play MP4 videos. Google to find tools to convert avi, mpeg clips to MP4 format and then play them on the W800i
paraman is offline
Old 06-07-2006, 09:33 AM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
3gp is the only way to go
use Nokia media converter or still better... get the Xilisoft 3GP Video converter
koolbluez is offline
Old 07-07-2006, 05:50 PM   #8 (permalink)
Neil is Here...
coolendra's Avatar
Yaar just use Xilisoft video converter to convert to 3gpp & MP4
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
